so the codes you have are:-
02 Control Unit Power Supply Value Too Low
0E Driver Side Airbag Squib O/C
0E Driver Side Airbag Squib Value Too High
0F Passenger Side Airbag Squib O/C
0F Passenger Side Airbag Squib Value Too High
09 Passenger Airbag Explosive Charge 2nd Stage Value Too High
32 Front Passenger Weight Sensor Internal Errors
is this correct?
This will almost certainly be the OCS mat control unit that comes attached to the mat. you wont be able to modify the circuitry to make good and will either need a new OCS unit (£300 from fiat) or an emulator (£50 off ebay)
- Front Passenger Weight Sensor Internal Errors
all these are possibly wiring faults but they should clear with a quick clean of the connectors, 'Value Too High' means there is high resistance in the circuit, 'O/C' faults are nearly always accompanied by the 'Value Too High' and the most likely culprit is a wiring fault... worst case is the airbag unit itself but these are expensive and dont 'usually' fail
- Passenger Side Airbag Squib O/C
- Passenger Side Airbag Squib Value Too High
- Driver Side Airbag Squib O/C
- Driver Side Airbag Squib Value Too High
- Passenger Airbag Explosive Charge 2nd Stage Value Too High
this is almost certainly a dicky battery or a stored code it wont be a blown fuse as you seem to be able to read the ECU
- Control Unit Power Supply Value Too Low
heres what i have found so far and i know its not complete so just bear with me i found it quite quickly with google
01 Airbag control unit ===> 'Clock Spring' of Steering wheel
02 Airbag control unit supply voltage
03 Control light for airbag system
04 Earth connection to control unit housing
05 Display for deactivation of airbag, passenger side
06 Crash Signal
07 Crash Signal
08 Airbag ignition circuit, driver side
09 Airbag ignition circuit, passenger side
0B Seat belt tension ignition circuit, driver side
0C Seat belt tension ignition circuit, passenger side
0E Sidebag ignition circuit, driver side
0F Sidebag ignition circuit, passenger side
12 Resistance seat-occupied sensor, passenger side
14 Keylock switch for disabling passenger airbag
15 Driver side front side impact sensor
17 Passenger side front side impact sensor
19 Cable configuration
1A Warning lamp circuit
21 Ignition circuit, window bag, driver side
22 Ignition circuit, window bag, passenger side
28 Power supply
2F = 47 Rear driver's side airbag explosive charge
32 Front Passenger Weight Sensor Internal/Unknown Error
34 Passengers Side 1st Stage Head Curtain Airbag Front
if anyone has a full list of codes ill add it to my OBD2 Excel document and update in my sig
