Off Topic Wheel OffSet
Wolverhampton
Can someone tell me if the offset is the same for Fiat Blades and Fiat Claws?
I suspect its not.
Edit.
Do Blades and Claws only fit Stilo's? (asking because someone moved this into the Stilo section).
Usually cast into wheel somewhere maybe have to whip wheel off and look on inside I'm sure I've seen et41 on the forum before.
I've been running some 15mm hubcentric spacers for a while now that brings the wheel closer to flush than o.e.
Looking in manual you have 7j x16 and 7j x17 et41 and 6 1/2j x15 et43
So il guess if blades and claws are both 17" yes both 41et offset.
And spare rims are all 4b x 15 et 35
These are from a 2006 owners manual.
The offset of a wheel is normally written on the back probably on a spoke rather than rim. It is the measurement from the inside face of the wheel where it bolts onto the hub and the centreline of the rim. This is why it will vary depending on the rim width but the inside spacing of the wheel off the strut will be the same.
