As the title says, there seems to be a new problem developing on my Stilo
I noticed it at the beginning of the week, whenever I pull away in first gear from a standstill there is a slight clunking noise coming from the front. It done this a few times and seems to happen if you use a bit too much clutch and less gas to pull away. Tonight I noticed that at high revs there's a sort of clunking again and I can also feel it a bit through the gas pedal, it only happens from 3.5k rpm upwards (I don't go past 4k so it's a narrow rev band it happens in). However when I parked up tonight I revved the engine up to 3.5k rpm and the noise/vibration was not there and didn't occur when I put it up to 4k rpm.
Can anyone pin point or give me general feedback on what could be causing this? It only seems to happen when the car's in gear so maybe a gearbox issue? Cheers for the help in advance people
