MentalMick
Hello all. I wonder if anybody could try and help me with a little dash problem i have please?
I have just bought (a couple of weeks ago) a 2006 Stilo 1.9JTD. The car has quite obviously been sat a long time and has not been used (at least a year i would guess). It has a dash problem that i am trying to sort out but it does not seem to have the same issue as others i have seen on here.
Basically the speedo, rev counter and temp gauge don't work. The fuel gauge appears to be working as it was at the top of the red bit and has dropped a little. The fuel low light is on along with the temp red light, glow plug light, handbrake warning light, ABS light and the yellow triangle in the middle of the dash. All the other lights were also on but one by one i have fixed them as there were a lot of bad connections on fuses and earth leads.
I have plugged a scan tool in and the fault it give is U1700 which appears to be a dash communication error.
My question is could the car have lost communication between the dash and the ECU due to being sat for so long (looks like it's had a new battery so i suspect the old one died)? If this is the case i am wondering if getting it proxi aligned might solve the issues i am still having? Everything else works as it should including seat belt and door warning lights etc.
Any help would be gratefully recieved.
Thanks,
Mick
Thanks,
Mick
