just fitted a new steering wheel off an abarth 500 and although i connected all the plugs up correctly the horn does'nt work? its not the fuse so it must be something i've done. i was wondering if anyone knows how the horn system works behind the airbag? presumably one of the connectors must work the horn but its the same connector as the old one so in theroy it must work? also, i noticed when i took the old one off that there was a big plastic disc that all the wires come out of that sits around the splined end of the shaft that the wheel slides onto. is this what activates the horn when you press the centre of the wheel?
