| Selespeed "Klonk"ing noise when changing gear Any of you guys with selespeeds notice any rattle or lacking a better word "klok" sound when it changes gear. Its barely noticeable with radio but if you turn it off I can distinctly hear it especially 2-3 and 3-4 and even feel it. just wondering what it could be thanx
| Re: Selespeed "Klonk"ing noise when changing gear sometimes, it has been there from new and at 66000 it has not caused a problem. Nothing to worry about I 'spose.
| | #3 | ||
| Re: Selespeed "Klonk"ing noise when changing gear Its the clutch engaging, mines done it since I had it, only really noticeable changing from first to second at low speeds. That would explain why I don't hear it very often.................
__________________ Stilo Abarth BLACK !! 02, 3dr....... | |||
| | #4 | ||
| Re: Selespeed "Klonk"ing noise when changing gear mines the same, only notice it when changing down at low speed in 2nd to 1st - I just cross my fingers and turn up the radio, don't notice it if the revs are higher though.
| | #5 | ||
| Free dentistry available | Re: Selespeed "Klonk"ing noise when changing gear I have never noticed it, i drive with my cd player off quite a lot as i like to here the exhaust note and have not heard anything like you described
__________________ ![]() | ||
| | #6 | ||
| 5vp3r m0d | Re: Selespeed "Klonk"ing noise when changing gear I do hear the noise occasionally, usually at lower speeds and between 1st and 2nd. I just ignore it.
__________________ Electroclash Panda 100HP ![]() Red brake calipers - done / Red highlights on engine cover - done Red GSR kit - done / Red badges - done / Cobra springs - done ![]() ![]() | ||
| | #7 | ||
| Re: Selespeed "Klonk"ing noise when changing gear i see. 1-2 is fine , I barely hear it. normal sound of clutch engaging. but then it gets louder 2-3 +. sounds like something is not put together tight enough and moves when changing.or like the clutch cannot slide back neatly but just kicks back at once though the change is smooth. ill have it checked eventually when i have the time, but thanx for now guys.
| | #8 | ||
| 5vp3r m0d | Re: Selespeed "Klonk"ing noise when changing gear Ok, been listening out more for this recently - can also hear it on 2-3, and possibly 3-4 BUT only when I am driving it slowly. To be honest, I am not that concerned, YET
| | Firewarrior | Cinquecento / Seicento | 16 | 17-04-2005 02:23 |
| | madmish | Punto | 8 | 28-12-2004 00:47 |
| Reverse Gear Noise - Punto | Squeak | Lets Talk FIAT | 1 | 22-11-2004 01:28 |
| | Squeak | Punto | 2 | 21-11-2004 21:00 |
| | joel | Punto | 4 | 08-06-2004 00:34 |
