mighty war horse
- Dec 17, 2011
- 3
- 1
I'm looking for some help with my 02 plate 1.9 jtd stilo. I'm a bit new to forums so you will have to bear with me but thanks in advance for any help.
Apart from all the other problems that seem to come with fiats ( pre heat fault, car still starts at -9) (water in the fuel filter I've drained it and it made no difference) (abs fault fixed). The main problem now is the throttle response. The other day the throttle developed a dead spot, the engine was still running and no lights came on, if I pressed the pedal to the floor it picked up again, or if I come off and back on the pedal. I thought the pedal potentiometer was faulty so fitted another pedal this sorted the problem for a few days and 100 miles, but now the problem is back as bad as ever.
Is this a common easy one any help appreciated
