Technical how to change selespeed oil?
Nobrain
Timisoara
hi,
the question is in the title.
how to change the oil for selespeed?
the pump doesn't create presure and i want to change 1st the oil too see results.
also how to remove the pump if it is broken?
Managed to take down the selespeed pump and to change oil.
Took us a couple of hours, but now that we know, it's a 2 hours job.
Removed all selespeed oil from oil tank with a syringe.
Can't describe it in details, i was just support, my god-father did all the hard work.
Most of it it is hand coordination, u can't see nothing. Pump has 5 screes, 4 holding it, 1 for oil bleed. Accessed the screws from under the car and driver side wheel place (took wheel off). Took the pump down. The connector for the pump is on the left side as you look at the selespeed oil tank, disconnect it. Also there you can see the relay of the selespeed pump.
The pump is half of a normal king size cigarette pack, rest of it it is the electromotor (electric motor). (The nipple you see from above is the electromotor and pump is attached to it - bottom side)
During disassembly we hit with a wrench a screw which didn't want to come off and noticed the pump is working. So it was the electromotor which is turning the pump.
Disassembled the electromotor and it was filled with black dust from the charcoal brushes (brushes look like a 90 degrees angle parallelepiped). The brushes were small. Took the brush out (careful with metal holding the brush, can be broken if operated hard) and called it a day :)
Next day we hit shop after shop to find replacement of those brushes. After 3-4h of search we found one almost similar (1.2 euro). Cleaned the inside and all parts of the electromotor with air jet.
Replaced brushes, tested pump on car, fitted the pump back on, put oil on, car works perfect. Will monitor it for a couple of days.
Total costs = 26.2 euros
brushes = 1.2 euros
cs speed oil = 25 euros (2 liters used only 700 ml)
PS: please change topic name "Selespeed pump not working - electomotor problem"
I need to remove my gearbox to replace my clutch. 126,000km on the clock. I think while I'm there, I should change the brushes in the Selespeed pump. This thread seems to confirm that would be a good idea, to extend the life of the pump motor :)
Has anyone else changed their brushes (or had their brushes fail - and if so, at what mileage?)
Also, any hints on which brushes might fit? I didn't quite understand what a 90-degree parallelepiped was - perhaps they had worn to a trapezoid shape, but were previously rectangular? Auto electricians these days are less helpful at finding substitute brushes than they used to be. There are different brush materials - I wonder if these are just-carbon or a copper-bronze colour. I put carbon brushes into a wiper motor once and they wore out quickly. I think alternator brushes might be a safer bet.
I'll be replacing my starter motor brushes at the same time (unless they are more than 6mm long). My experience is that whenever a starter motor is removed from a car that's more than 10 years old, it should be cleaned, lubricated, and have the brushes replaced for ongoing dependability. I'm pretty sure this will apply to the Selespeed pump as well, but just thought I'd do a little research too.
As for the original topic of this thread, I presume that most of the Selespeed fluid will drain when I take the pump out. The fluid in the reservoir is very dark (like old brake fluid) so I intend to refill with fresh fluid. Good to know that 1 litre might be enough.
-Alex
-Alex
Yes, however before you do this, using MES drain the system completly, A) to get most of the oil out so you're not mixing much old with new, and B) to remove system pressure when playing with it (y)
