hi, i have a 1.8 16v stilo sporting, its using all of its engine oil after 1000 miles, this has happened twice now, its only done 51000 miles, is the engine buggered? there is no smoke and the engine is dry? thanks
@vladof:- its called a valve cover or a rocker cover... the piece covering the valves...
The diesel sound has nothing to do with any hydraulic lifter. It's coming from the valve variator. Only the 1.8 and 2.4 engine in the Stilo have this. If you don't know what that is, read the info below:
Variator (variable valve timing)
Take it to a decent garage to have it looked at for leaks. That's about how much my father's car was losing through the rocker cover (thanks Richy ) and nobody had a clue why.
Thoroughly chech the underside of the car for minor leaks, although you would be surprised that 1l of oil can just leak and not leave any spots on the tarmac where you parked.
Sixpotman is right, if you don't have the right oil the car can consume some, but clearly not as much. I drive mine in a mixture of sporting and slow. Still doesn't take any oil whatsoever. Selenia 20k.
It's common not to use any oil. You have a huuge problem, definitely. I have a 1.6 and sits at 4000RPM driving with 140km/h and I drive and drove like that for a long long time and I did >100 000 kms since I have it and it has never used any oil even a little bit… and I use 0W40 grade oil which come people consider too thin If you buy a brand new car (or rebuild your engine) and don't run it in properly for the first 500-1000kms it's normal to use some oil but if it's a consequence and happened recently you have a problem. It’s a mystery to me how you didn’t notice any blue smoke or leak somewhere. Try that: go downhill, gear engaged, foot off the gas pedal, have someone drive right behind you, go like that for a minute then floor it, see if smoke comes out.well its been going up and down the motorway alot lately and it does rev very high, 80mph and 4k revs, i normally sit at around 65-70 to keep it down a bit so maybe thats why its using alot, is it common for the 1.8 to use lots of oil?
Got me wrong, the only problem you have right about now is topping up. The engine will neither seize nor let you down in the middle of nowhere, so don't worry. Keep an eye on the dipstick and be happy. Do the test I told you. Check for leaks in the back of the engine.. but you should probably have spotted them on the street already. That’s the problem with changing oil every 20000 miles and buying a car whole Italy has given a good time for the past ten years. Fiats are great cars get a brand new one or one with genuine service history. Is it still going strong? Any loss in power?riigghhht......... if its a huge problem then il scrap it, not worth repairing, ive left it on tick over for 5 mins and pulled away, dad was standing behind the car and there was no smoke, some people on here have had the same problem so not going to worry about it this side of x-mas, im not using it to go far anymore, just short runs to work and back every day, il check the oil tomorrow and see if its used anymore. thanks
or a valve variator? how do i change them?
I have 1.6 my 2002 and my oil consumption is about 1litre per 3000km, thats quite a lot.
I bought Stilo cca 3 years ago, I made 50000 km on my own. The oil consumption is still the same on this 3 years.
I do not see a blue cloud behind, or oil leak under. I think power is ok.
My friend has 1.6 MW with similiar oil consumption...
I think some Stilos have this problem - probably depends on previous owners (oil changes, style of driving...)
my other one was a 1.6 with loooaaaadds of engine mods and tbh it had been cained. but that didnt use any, this one has been very well looked after and uses loads.
Same oil brand in both of them?
