hi guys, i need your help or advice on this, today i done and oil change and a coolant change and now the engine managment light has come on? i'm pretty sure its something i've done so i'll run though how i done things and maybe someone can shed some light on whats going on?
done the oil and filter first, nothing unusual there - i used mobil 0w 40 and put the correct amount in (4.7 litres)
then drained the coolant out, flushed it with cold water, refilled with as best as 50/50 as i could and ran it up to temp. everything was fine for a while, did all the usual methods to bleed as much air out as i could like squezing the hoses, undoing the bleed screw and turning the heater to hot, which it start to do. i then took it around the block to get it really hot so to check for the fan to cut in. the temp rose to exactly half way (which is unusual?) and still the fan would'nt cut in then both the ASR light and engine management light came on
i switched the car off, then started it back up, and the ASR light when off, but the "check engine" warning message is still on??
has anyone had this problem before?? i'm almost certain its something to do with the coolant job i did, its not overheating despite its unusual temp reading plus if it was why does'nt the temp warning come on?
i do have a hand held diagnosic device that plugs into the car but can't seem to find any plugs?
any thoughts on this would be really helpful as i don't wanna do any damage whislts driving it?
