Brake light fail indication but all stop lights working. 3 dr JTD 115 2002
I had this problem at the beginning of the year and cured it (or so I thought) by adjusting the switch plunger as per Deckchair's excellent guide.
The brake lights have worked fine all summer but with the onset of the damp weather the fault has reappeared so I treated the car to a new brake switch because I have just retro fitted a cruise control which I felt would have no problems with a good working brake switch.
Sad to say, no difference, the brake lights (lo & Hi level) work fine but the "Brake warning fail" & triangle sign are still there.
I had thought the dampness was causing intermittancy in the switch because it worked after a reasonable time driving with the heater on but this is obviously not the case.
Any ideas would be welcome.
