The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 13-04-2005   #1
Trader Rating: (0)
South Africa
Connect Nav+ CODE
I am still waiting for NavTeq to reply about maps for South Africa, but in the meantime I saw someone selling a unit on a german site. I asked if he had the CODE and he replied...
"I don`t have the Mastercode for the CN+, but it isn`t required to get the CN+ working. All you have to do, is to connect the CANBUS A-Line first, after that connect the CANBUS B-Line. With this you override the Mastercode on the CN+."
Is that correct? Surely it is required, or anybody stealing it could also use such a simple method... (not that I know what he is talking about, but obviously its something you do when installing it, and it seems a little bit too easy)
Tx!
radicool is offline
Old 13-04-2005   #2
All Hail the Woodsman
thepottleflump's Avatar
Trader Rating: (0)
thepottleflump has donated! United Kingdom
Re: Connect Nav+ CODE
I've never had to enter a code on my Connect Nav+ when disconnecting the battery or even when fitting a CDC, so it may be true.
Fiat Bravo T-Jet Sport / Strada 130TC (currently undergoing restoration)
www.strada130.com
thepottleflump is offline
Old 13-04-2005   #3
Banned
Trader Rating: (0)
Ben R has donated! Christmas Island
You only enter a code that YOU have selected from the setup menu.
Ben R is offline
Old 13-04-2005   #4
pjp
Trader Rating: (0)
My CN+ came with a 4 digit PIN code - if I remember correctly, it is required if the unit is unable to obtain the correct serial number from the body computer that it is matched to.
Stilo Abarth Selespeed 3dr, Broom Yellow (Nov '03)
Ulysse 2.0 16V EL, Forest Green Metallic (Oct '01)
pjp is offline
Old 14-04-2005   #5
Trader Rating: (0)
Germany
You actually have to enter a 4 digit pin code. there might be models out there which don't require that though (different fiat part no's...)
The thing with the can bus lines is correct though. works exactly that way.
best,
lars.
5d 2002 Stilo 1.2 in stone gray, Abarth dash + Connect NAV+, a few more goodies, just ask =) nice car!
2005 Punto MkIIb 1.4 Emotion fully loaded.
larzmaster is offline
Old 14-04-2005   #6
chromegrey's Avatar
Trader Rating: (0)
who makes the cn+?
Cars owned
1997 - 2002 Seat ibiza, 2002 - 2004 Punto HGT
2004 - 2006 - Stilo JTD (remapped)
2006 - Rover 25IL / Peugeot 206 sport / Subaru
2008 ? could be GPS or MCS
chromegrey is offline
Old 14-04-2005   #7
Trader Rating: (0)
Germany
It's Blaupunkt-designed and manufactured by Magneti Marelli.
Old 15-04-2005   #8
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
I thought it was Visteon?!
Although I am aware that the CN+ in the Ulysse is made by Magneti Marelli.
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
Old 15-04-2005   #9
Trader Rating: (0)
South Africa
I also read somewhere that all the Stilo headunits were by Visteon.
radicool is offline
Old 15-04-2005   #10
chromegrey's Avatar
Trader Rating: (0)
Magneti Marelli make the CN+
other stilo radios are made by Visteon
Cars owned
Old 16-04-2005   #11
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Thanks for clarifying my misunderstanding
Found this on the MM site:
Old 18-06-2007   #12
Trader Rating: (0)
Help me please!
I bought Fiat Stilo 2002 with Magneti Marelli Connect Nav+, but I haven't code.
I made all steps as described here:
http://freenet-homepage.de/fk2000/cn...cn+_einbau.htm
but it doesn't work
I disconnected pin 3 first, switch ignition ON, but spidometer not blinked
I try to disconnect pin 1 - without effects
CN+ worked until ignition is OFF. If I switch ignition ON - CN+ write "Enter Code"
Maybe I can do anything else?
Aser is offline
Old 18-06-2007   #13
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Ok, is this a factory installation or an after-production job?
If by "Pin 1" and "Pin 3" you mean CAN-A and CAN-B, doing so is pointless as they are both needed for the CAN-BUS to work at that node.
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 18-06-2007   #14
Trader Rating: (0)
1. Factory
2. Yes. These CAN-BUS. I try to disconnect both pins 1 and 3 and CN+ worked with ignition ON, but management on a rudder did not work
Aser is offline
Old 19-06-2007   #15
Trader Rating: (0)
Addition info:
FIAT Stilo 2.4i 20v 2002
VIN: ZFA192000*00099463
Numbers on CN+ (back cover):
Magneti Marelli
0681
500189440130880
735297003
Please help me.
Aser is offline
(T) how do i connect a sub to connect nav + scrod Stilo 3 24-02-2005 16:16
New Ulysse Connect Nav + Stu DemonD Ulysse 126 18-06-2004 01:16
(T) Connect Nav -vs- Connect Nav+ Mikas Stilo 7 30-04-2004 02:38
(T) SOS button + no manual for connect nav coolchef Stilo 5 04-09-2003 04:46
Connect Nav - How do I Play[?] Gladiator111 Multipla 1 06-07-2003 00:22
