neonglow
Member
- Jul 12, 2010
- 347
- 53
I agree with you Selenia 10W60 is a good oil and will do it's job just fine. I just said that the Selenia 10W60 isn't a fully synthetic oil and is the same as Selenia 20K which is not a bad oil at all! It's just that there are a lot better oils out there. Also don't be fooled by the 10WXX branding it's the kinematic viscosity @ 40º C, @ 100º C and the HTHS figures that determine how "thick" and oil is. There are 5W40 oils out there that are thinner at 40º C than the Mobil 0W40. Also your 2.4 engine is never going to develop higher oil temperatures than a 1.8 or a 1.6 not to mention a turbocharged engine and you will never see it pass 70 degress centigrade on a hot summer day after some very hard driving. If they say you should use 10W60 than the engineering tolerances in that engine require such an oil i.e. the 1.6 obviosly does not like an oil thicker than 40, I once put in some 5W50 and I could here the tappets at all times with the 0/5W40 it's rather quiet. Another thing I also wanted to point out is that the thinner the oil when cold the better for the engine – 90% of engine wear occurs during startups. An oil with big difference between warm/cold grades are very difficult to make require quality PAO basestocks and special viscosity modifiers and that’s the reason they are so expensive. It would be best if there was an oil with 0W60 grade but unfortunately no such things exist. Also Ferraris, Porsches, Lexus (LFA), AMGs etc have Mobil 1 0W40 as a factory fill I doubt that it’s just corporate politics there.I have limited access to the Selenia 10w60 oil technical information but which ever way I am not going to contrast any more opinions further, I hear your words, maybe the Selenia is not the best multigrade out there...which ever way I wont be changing the oil what ever the comments or arguments are brought up The Selenia 10w60 will do me just fine, my cars purrs and loves the juicy stuff :yum: so its also not complaining about its new supplements that it has
For you guys that keep on suggesting that people in the UK need to accommodate their cars with a lower _w oil viscosity for winter temperatures, in central Europe and many other far eastern European countries you guys may experience severe temperatures below -20 °C, sure you guys will need to accommodate it for those temperatures but in most parts of the UK, you will never experience those kind of tempreatures.....
