| Ipod / Connect Nav+ connection Hi all, Ok, I've had my dension ipod connector delivered with the Blaupunkt interface for the ConnectNav+ headunit - everything is ready to go, removed the backing from the glove box to find that as expected Fiat haven't run the wire from the back of the head unit - no fear, the cable I have is long enough. But I have no idea where the CDChanger port is on the back of the Nav+ system. Can anyone give me any ideas, anyone got a photo of the back of the ConnectNav+ units? I'm hoping I can run the cable round to the right place without having to remove the unit itself!! Cheers, Chris
| Join Date: Apr 2004 Location: stenhousemuir/scotland, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Where's the CDChanger Port on ConnectNav+? there is only one free port on the back of the connect+ so you cant go wrong. unfortunately you will have to slide the unit out to get in to it. it is easily done, there is a thread on here somewhere but it basically involves sliding 2 bits of cut up coat hanger into the holes in the front of the unit to release the retaining clips and then give it a push from the back.
__________________ http://www.ek1.pwp.blueyonder.co.uk/metalboot.jpg | ||
| | #3 | ||
| Re: Where's the CDChanger Port on ConnectNav+? Well I took another look and you wouldn't believe it but Fiat hadn't secured the head unit in place, so no coat hangers needed - the whole thing just slid out! I have my iPOD connected to the CD changer interface and it looks like its picked it up - I'll drop a note back to let you know how I get along! Cheers, Chris
| | #4 | |||||
Hi can I ask where you got this from and (gulp) how much it cost? Cheers Steev
| | #5 | ||
| Re: Where's the CDChanger Port on ConnectNav+? I'd really like to connect my i-pod to the Sat-nav+ unit so do please tell me how you've done it!!!!!!! What did u buy and where did u get it from?????!!!!!!!!! I've got the CD changer, so does that mean i can't have the i-pod plugged into the system or can they both share the conector?????? I'm really interested in this subject so any help would be excelent!!!!
| | #6 | |||||
| Banned | Re: Where's the CDChanger Port on ConnectNav+?
| | #7 | ||
| Re: Where's the CDChanger Port on ConnectNav+? Well, i allready spent 450euros un the Cd Changer + glove compartment so i'd like to have both. Plus, as u can't control the i-pod from the wheel i'd still like to have the cd changer available. It's always best to have both if possible!! Info about this subject would still be very helpful Thanx
| | #8 | |||||
| | #9 | ||
| Re: Where's the CDChanger Port on ConnectNav+? Really??????????????????!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Does that mean i could control it from the sat nav on the Stilo and from the controls on the wheel???? That would be PERFECT!!!!!! I'd give a kidney t o be able to do that!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Is your father's car a Stilo??? Thanx for the info, i'll try and look it up
| | #10 | ||
| | #11 | ||
| Re: Where's the CDChanger Port on ConnectNav+? Sorry all, I've only just got back onto the site to find all the replies!! Bennyboy66, you're right i bought the Dension IceLink Plus connector (http://www.dension.com/icelink_info.htm) from David at www.ihavetohave.it, they're the main supplier for the dension kits in the uk. Basically the design is really simple, the iPOD connects to an interface which in turn connects to the CDChanger interface - it took 5 minutes to hook up and the CDC button is now available from the ConnectNav+ screen, the cable then routes through behind the glove box, where I have placed the interface unit, the remaining cabling runs round to the right hand side of the glove box where it pops through (no holes needed), I leave the ipod in it's cradle in the glove box. How does it work? Well you can select everything through the iPOD, or use the controls on the steering wheel - or even voice commands. Your first 5 playlists become buttons 1-5 on the ConnectNav+ unit. The iPOD will charge whilst it's in the cradle as well. Sounds good eh!! Now the honest bit ..... it's not working!! Dension are working on the ConnectNav+ issue now - they know about the Fiat specific Blaupunk version and they have some units working, others including mine arn't (I have v9.8). They're working to a 5-6 week fix at the moment, all thats needed is a quick firmware update which is easily done through dropping some files onto the iPOD through iTunes. I have been given the oppertunity to return the unit and get my money back, but to be honest I don't want to - it works on a huge number of other cars and I trust Dension will get it sorted out, I've been waiting ages to get the iPOD connected so if anyone is interested, help the process along by emailing both David and Dension on Support@dension.com and sales@ihavetohave.it lardarse - you wanted to know how much, £99.99 inc vat. Stilo Multijet - you cannot connect both the CD Changer and the iPOD - it's one or the other, but I'll be honest, why would you want to - you can use the headunit to control the ipod. Chris
| | #12 | ||
| Re: Where's the CDChanger Port on ConnectNav+? I've just had an email from Dension, they have the ConnectNav+ head unit with their development team right now, so it may be a lot sooner that 5 weeks. Chris
| | #13 | ||
| Banned | Re: Where's the CDChanger Port on ConnectNav+? Cool! cheers for the info Chris I shall order the ice link in a couple of months. Thanks again.
| | #14 | ||
| Re: Where's the CDChanger Port on ConnectNav+? That is good!!!!! Looks like i'm going to have to start selling my CD changer!!!!!!!!!!! Or mybe i can install some sort of a switch that will take me from the i.pod to the CD Changer and vice versa, that would be excelent. Thanks for the info guys that was really helpful, now i just have to find out how to get the equipment in Spain!!!
| | #15 | ||
| Banned | Re: Where's the CDChanger Port on ConnectNav+? Try clicking on the links Chris posted & email the company to see if they will send you one.
| | Ben R | Stilo | 7 | 27-03-2005 11:40 |
| Sub connection to connect nav + | Ben R | I.C.E | 1 | 17-03-2005 11:00 |
| New Ulysse Connect Nav + | Stu DemonD | Ulysse | 126 | 18-06-2004 01:16 |
| | Mikas | Stilo | 7 | 30-04-2004 02:38 |
| | coolchef | Stilo | 5 | 04-09-2003 04:46 |
