Not got the new keeper part of the log book?
Yes but its not in the best of condition.
well, not actually that bad, could be salvageble...
the area causing concern is the bottm chip, bottom left hand corner, not sure what the extent of that damage is....
i was refering to the two you removed (top right)...admittedly, i was v unclear
its the bottom left of the area you worked on that looks damaged.
So a second hand Body Computer can be used as they are easily reprogrammed using the Proxi-Alignment Proceedure in FiatECUScan.
However the Imobiliser Key Code is stored in the BC and the Engine ECU so a £90 "Fiat Dealer Only" re-coding of the key is needed unless the Engine ECU from the donor car is also used. This may not be too much of a problem if both cars are JTD's for example, but if the donor car was a 5 door 1.6 and the other was a JTD Multiwagon you have a problem and taking it to a dealer for a £90 re-coding of the key would save a lot of time and money.
I suspect a lot of the unsolveable strange dash, door and light faults etc. are probabely faulty BC's.
I have the flashing odometer (I didn't swap the instrument panel). I tried to do a proxy alignment, but it won't stop flashing, I think because there is climate control. I gather from comments earlier in this thread that it still isn't possible to proxy-align the climate control node?
