The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 04-04-2005   #1
stef78's Avatar
Trader Rating: (0)
stef78 has donated! United Kingdom
Exclamation Water
When i purchased my Abarth lat November i was cleaning out the inside when i noticed that the drivers side foot well was damp & on the left hand side near where the foot rest is there was a trickle of water?.
So i took the car into the dealer and they gave it the once over and send that they couuld not find anything !
So i left it and then yesterday i was giving the car a little clean when pulled the drivers mat up and yet again the floor was damp and there was a little trickle of water coming from the same area again !.
Has anybody out their had the same issues or have just got to buy a pair of waterproof shoes !
Fiat Bravo Trofeo 1.6 X Reg Fiat Stilo Dynamic 1.8 02 now Fiat Stilo arbath 2.4 what next
stef78 is offline
Old 04-04-2005   #2
froggie 666's Avatar
Trader Rating: (0)
Ireland
Re: Water
Hi Stef,
Are you noticing any coolant loss? if it is "water" is can only be one of three possibilities:- Coolant - washers or an external leak. If there is a trickle in the car try smelling & tasting it, no I'm not winding you up! antifreeze has a very bitter tang so should be easy to identify, my guess is a leak from outside, wait for a dry day and try leaving the hose pipe on the front scuttle to see if you get the trickle to start. Hope this helps matey keep us posted
Regards Steve.......
EDIT: I have a spare pair of size 10 wellies...........
Stilo Abarth BLACK !! 02, 3dr.......
froggie 666 is offline
Old 04-04-2005   #3
Trader Rating: (0)
Spain
Re: Water
Mybe it could be somthing to do with the air conditioning????? You should try leaving it on max for a while and see whet happens.
Otherwise, just put a nice big bucket down there!!!!!!!!!!
Stilo Multijet 140bhp is offline
Old 05-04-2005   #4
Paparrazi
Trader Rating: (0)
Neil Barker has donated! United Kingdom
Re: Water
Had this on my previous Abarth - it's condensed water coming from capillary action due to the air-con. A pipe needs slightly re-routing, IIRC.
Neil Barker
Techno Grey 3dr Abarth Selespeed now replaced by a 2008 Toyota Avensis TR 2.2TD
Sadly, I am unable to recommend Sunwin Fiat Derby due to my experiences there
Neil Barker is offline
Old 05-04-2005   #5
unosy22's Avatar
Trader Rating: (2)
Re: Water
it could be leaking in through the heater or pollen filter at a guess!
we do a few water leaks where i work it may be on f**d's but it could be worth looking at?
sy
K&N filter for sale for cinq sporting,uno1.1,punto 55.
Originally Posted by 1986Uno45S View Post
"Bob the Cento,CAN WE FIX IT?Bob the Cento,YES WE CAN!"
unosy22 is offline
Old 05-04-2005   #6
James M's Avatar
Trader Rating: (0)
Re: Water
I had the same thing with my JTD, it turn out to be an A/C condensate pipe come loose. If you have the same thing, you will probably find the water has a bad smell to it.
If it is this, get your dealer not only to fix it, but also to fully deodorise and clean your car, as the smell will become truly awful as the weather gets warmer.
James M is offline
Old 05-04-2005   #7
stef78's Avatar
Trader Rating: (0)
Re: Water
Originally Posted by froggie 666
Hi Stef,
I have done the Taste test and its dosent taste like Mansfield Bitter!.
and there is no naste taste to it so it may be coming from outside
will check with the hose pipe later this week
Thanks Buddy for the speedy reply
stef78 is offline
Old 05-04-2005   #8
stef78's Avatar
Trader Rating: (0)
Re: Water
Cheers buddy but any ideas where i find the said Pipe
Buddy Regards Stef78
stef78 is offline
Old 20-06-2005   #9
stef78's Avatar
Trader Rating: (0)
Exclamation Re: Water
I posted this thread months ago and i was still gettiing a bit of water in the foot well every now and then ? but the guys down at Fiat said no Sir i can tell you hand on Heart that there is no problems with your car.
So on Saturday when we were having very hot weather i went to put some petrol in at the garage.
When i came back it looked like the foot mat was going to float off down the road
So i took the car straight down to the dealer where i had to wait ten minutes for the guy to finish bidding on E Bay???????. So i told the guy the problem and he got a mechanic from around the back in 5 minutes he had look and told me that a drain pipe from the air con was missing ?? i then asked why they didnt spot this before ??? no reply.The guy then went into the show room and robbed one from a Active sport with Arbath sideskirts 05 reg. which was a result for me but i bet not for the new owner of the active sport.But i can not complain they did it on the day but it took them three months to find it
stef78 is offline
Old 20-06-2005   #10
5vp3r m0d
Stu DemonD's Avatar
Trader Rating: (1)
Stu DemonD has donated! United Kingdom
Re: Water
You could be right
Electroclash Panda 100HP
Red brake calipers - done / Red highlights on engine cover - done
Red GSR kit - done / Red badges - done / Cobra springs - done
Stu DemonD is offline
(T) my water is missing? helicopter_red Cinquecento / Seicento 2 21-02-2005 23:23
(T) Water Leak martin.butler Punto 2 20-02-2005 21:08
Water level decreases rapidly Spambam Tipo 8 22-07-2004 01:04
(T) Help!! Leaking water!! Sando Cinquecento / Seicento 1 08-10-2003 14:08
(T) Punto Turbo oily Water Problem didgey101 Punto 6 09-04-2003 20:28
