Ok , I reconnected the CB to the loom, put a MM across the o/put connectors of the CB that would feed the i/put to the fan itself, and turned ignition on and turned the climate control fan from min to max:
Min o/put of CB = 12.26V
Max o/put of CB = 12.17V
Range from max to min stepped up in 0.01V increments.
Then I measured across again, this time with the fan connected:
Min o/put of CB with heater fan connected = 2.45V
Max o/put of CB with heater fan connected = 2.9V
When I repeated this with the ground to the seat mount bolt:
Min o/put of CB with heater fan connected = 11.82V
Max o/put of CB with heater fan connected = 11.8V
MM across Pin 1 = 0.01V min and max(?) earth of CB and seat mount bolt.
Max o/put request speed voltage (Pin2), earth o/put CB, fan connected = -3.31V
Min o/put request speed voltage (Pin2), earth o/put CB, fan connected = -8.16V
Max o/put feedback voltage (Pin1), earth o/put CB (fan connector), fan connected = -8.72V
Min o/put feedback voltage (Pin1), earth o/put CB (fan connector), fan connected
= -9.2V
Is the fan at fault, as when it's not connected, there's about 12V on the CB output for it, but it drops right down when connected?
