Hi!
Today when i started my stilo everything was fine until i touch steering wheel..i got power steering fault, i cheked fault codes and there was 2 of them.
c1007 - actuator
ecu fault low or high voltage
I reseted faults and started car, everything is fine..no faults and power steering is on. until i rotate steering wheel, at that time i got power steering fault again...Now there is only 1 fault code C1007 - actuator.
I tested it couple times and everytime it happened like that,everything is fine until i rotate steering wheel.
Is there any other solution to get it work except new steering column..
c1007 - actuator
