Just in case it helps someone here, I found that shorting pins 13 and 14 was the trick to get my Fiat Panda 2012 62 plate with bog standard radio to go into aux mode when pressing the media button. Before doing this, the media button just kept resulting in 'no source available'.
Once you short pins 13 and 14 (CD changer data+ and CD changer data- on the pinout above), pins 18,19,20 are then active as aux in.
Interestingly, on the pinout diagram on top of the stereo, pins 13 and 14 are not even labeled.
