Hello! My cluster was completely silent, and nothing was working. So I had to open cluster to solder it and I pulled out those pins on thermo and fuel gauges. Soldering worked and now cluster is working, except motors heat and fuelgauge.
Can I fix those white meterthings without spare parts? Do I need to increase the size of the opening, like you tried or do you have any better ideas? Did you use drill to get hole bigger?
