Fault diagnosis >
C GEAR SHIFT >
C25 THE CAR GOES INTO NEUTRAL BY ITSELF
Whilst stopping
Travelling at a speed of below 40 km/h
When stationary with a gear engaged (1st, 2nd or R)
Results of the tests
OIL LEVEL CHECK
All OK
Problems met
Operation
Check the oil level See Test
2127B OIL LEVEL CHECK
Continue to Step
2
Level below Max reference
Top up the level
Continue to Step
1
Level above Max reference
Reduce to the Max level
Continue to Step
2
1
CHECK FOR OIL LEAKS
All OK
Problems met
Operation
Check that there are no oil leaks See Test
2127C CHECK FOR FLUID LEAKS
Continue to Step
2
Oil leaks detected
Replace/repair the relevant parts, and top up the oil level
Continue to Step
1
2
OIL PRESSURE CHECK
All OK
Problems met
Operation
Check the oil pressure See Test
2127D OIL PRESSURE CHECK
Neutral for low pressure only exists if the vehicle is stationary or moving at low speed (about 10-15 km/h)
Continue to Step
4
Pressure < 40 bar
Continue to Step
3
3
CHECK ON PUMP OPERATION
All OK
Problems met
Operation
Check that the pump is working properly See Test
2127E ELECTRIC PUMP OPERATION CHECK
Continue to Step
4
Voltage below 11 V
Check the battery
Continue to Step
3
It is not possible to make gear changes from the lever
Activate the 'clutch bleed' service from the Examiner Plus or Smart to activate the pump
Continue to Step
3
4
CONTROL UNIT ERRORS CHECK
All OK
Problems met
Operation
Check that there are no control unit errors. In particular:
- Microprocessor 2 error (in the following condiions: engine on, accelerator pedal released, brake not pressed and speed below 4.5 km/h)
- Errors on CAN network (in the following conditions: engine on, accelerator pedal released, brake not pressed and speed below 4.5 km/h)
- Engine speed (in the following conditions: engine on, accelerator pedal released, brake not pressed and speed below 4.5 km/h)
- Electromagnetic brake (Selection solenoid)
- Clutch solenoid current
- Clutch sensor
- Selespeed pump
Continue to Step
7
Presence of one or more of the errors included in the list
Continue to Step
5
5
CHECKS ON FAULTS DETECTED
All OK
Problems met
Operation
Check the faults See Test
2127I What to do depending on the error' present in the Selespeed control unit No accelerator pedal information.
End of diagnosis
One of the control units does not dialogue (Errors on CAN network)
Repair/replace the control unit concerned
Continue to Step
6
Faulty connection (Engine speed)
Repair/replace the part concerned
Continue to Step
6
Faulty connections (Electromagnetic brake, Clutch solenoid current, Clutch sensor and/or Selespeed pump)
Repair/replace the wiring
Continue to Step
6
The test is not successful (Electromagnetic brake)
Replace the solenoid valve Op.
2127C54
Continue to Step
6
There are no faulty connections (Clutch solenoid current)
2127C56 and check its operation by carrying out a gear change.
Continue to Step
6
There are no faulty connections (Clutch sensor)
Replace the clutch actuator (CSC) and check its operation by carrying out a gear change.
Continue to Step
6
Fault in pump relay and/or fuse (Selespeed pump)
Replace the component
Continue to Step
6
Faults on pump winding (Selespeed pump)
Replace the component Op.
2127C30
Continue to Step
6
6
AFTER THE CHECKS ON THE FAULTS DETECTED
All OK
Problems met
Operation
Check that the fault is no longer present
End of diagnosis
The fault persists
Continue to Step
7
7
DOOR SWITCH CHECK
All OK
Problems met
Operation
Check the state of the driver's door switch (it should be remembered that the system recognizes the opening of the door if the accelerator pedal is released for 4 seconds, the brake not pressed and the speed is below 4.5 km/h)
Continue to Step
9
The door switch is not working properly
Check the state of the connections, the wiring and the switch. Repair/replace the part that is not working
Continue to Step
8
8
AFTER THE DOOR SWITCH CHECK
All OK
Problems met
Operation
End of diagnosis
The fault persists
Continue to Step
9
9
CHECK THE CORRECT OPERATION OF THE LEVER
All OK
Problems met
Operation
Check the operation of the lever (remembering that neutral can be engaged with the vehicle moving at speeds below 40 km/h)
End of diagnosis
The lever is not working properly
Check the state of the connections and the wiring. Repair/replace the part that is not working
Continue to Step
10
10
AFTER THE CHECK ON THE CORRECT OPERATION OF THE LEVER
All OK
Problems met
Operation
End of diagnosis
Fault persists
Search for the fault starting from another symptom'
