Hello
Sorry to make this my first post without properly introducing myself.
I have a Stilo 1.6 16v with a bad stalling problem!
I purchased it from an auctions so I'm not sure how long its had the problem.
9 times out of 10 you can start the engine and it will idle fine but as soon as you touch the throttle and remove your foot from the peddle the engine will drop below 1000rpm struggle for a few seconds then stall. (making it completely unusable!)
Ive replaced the air flow sensor (which I believe is called the MAP sensor?) and also cleaned the throttle body out completely cleaning both sides of the valve. I have also checked and cleaned all the main connections under the bonnet.
Any advise on this problem would be greatly appreciated?
Thanks in advance
Karl (from lincoln)
Thanks in advance
Karl (from lincoln)
