My Stilo has 2 problems. First one - engine is difficult to start when its cold. I have to hold starter on for 10 or more seconds.
The second one is Engine Fault message and corresponding power loss when accelerating. When I'm trying to accelerate harder, engine sometimes is even completely switched off.
Here what FatECUScan reports at iddle speed:
Errors
P0191 - Diesel preasure control / Invalid signal / Fatal / Light ON
Parameters
(I can not post links to images here )
Engine Speed 852 rpm
Fuel Metering 8,77 mg/i
Fuel Pressure 298,5 bar
Fuel Pressure Signal 1,290 V
Desired Fule Pressure 300,0 bar
Fuel Pressure Regulator 18,74 %
Boost Control/Sol. 75,00 %
Boost Control/Sol. Not active
Actual EGR 1,00 %
Capacitor 1 Voltage 80,097 V
Pedal Pos. Track 1 0,679 V
Pedal Pos. Track 1 0,342 V
Vehicle speed 0,00 km/h
Air Temperature 5,4 C
Air temprature signal 3,548 V
Baro Pressure 1.005 mBar
Baro Pressure signal 3,979 V
Intake Air Quantity 52,7 mg/i
Desired Intake Air Quantity 295,6 mg/i
Air Flow Signal 2,331 V
Glow plug heater module Not active
CAN data line OK
Engine Temperature 63,1 C
Engine Temperature Signal 2,053 V
Engine/ECU stop Not active
What is the main suspect? Overboost valve? MAP?
Thank you.
Errors
Parameters
Actual EGR 1,00 %
CAN data line OK
Thank you.
