The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 06-03-2005   #1
Trader Rating: (0)
I ran out of petrol and now my car wont start HELP!!(FIXED)
Hi
I have a Fiat Stilo 2003 and the other day i went out to the shop in it (It started fine)and noticed that my brother that had lent it the day before had not put any fuel in it.
I keep about 3 litres in a can in the boot but i was only going about half a mile so i decided to wait until i got home to put it in.
I pulled up at home, turned the engine off and put the fuel in... but then it wouldn't start back up.
So from stopping the car to putting the petrol in and trying to start it again something happened.
None of the warning lights are on and i have reset the fuel cut off switch.
Could it be possible that the car was really low on fuel and sucked up some air and now there is air in the fuel pipes?
I have been trying to start it now for about 2 hours on and off...could it be flooded?
Do new car even get flooded anymore?
As you can tell im not really up on cars i know enough about old engines but not about these new engines that just look like lumps of plastic.
This is my check list
Is there fuel in=Yes (well enough to start it atleast)
Any Warning lights on=No
Fuel cut off swicth=Reset
Checked for leaking fuel=None
All HT leads on=Yes
Fuses=All ok (this is a last ditch attempt)
Im gonna go to bed now and hope that it is flooded and that in the morning it will start
If you have ANY ideas about what it could be can you please make some suggestions.?
Thanks in advance
res1492 is offline
Old 06-03-2005   #2
The Negotiator's Avatar
Trader Rating: (0)
The Negotiator has donated! United Kingdom
Re: I ran out of petrol and now my car wont start HELP!!
What engine?
If it is a JTD the problem will be more difficult.
Now drives: '52 Megane 1.9dCi
Past:
Y-reg Fiat Brava JTD (Pale Blue) (2006)
M-reg UNO (2003-2004)
'51 Fiat Brava 80 SX (black) (2006)
The Negotiator is offline
Old 06-03-2005   #3
smurfhead's Avatar
Trader Rating: (0)
Is the car on level ground. I tried restarting mine in the same situation before with the left side on the pavement and I guess the fuel wasn't near the pump. simple and easy mistake to make. Just push it on to the flat. If it is anything else, how to remedy it is way obver my head.
Gaz
smurfhead is offline
Old 06-03-2005   #4
Trader Rating: (0)
Sorry i forgot to add the engine
Its a 1.6(not JTD)
And the car is leaning to the right (As im sat in the drivers seat)
Also the car will try to start ..its turning over but it just wont kick in
res1492 is offline
Old 07-03-2005   #5
Koa
Free dentistry available
Koa's Avatar
Trader Rating: (4)
Koa has donated! United Kingdom
I had the same problem when my old VW golf ran out of fuel on a hill. I had to get the car level to start it back up again, also the rac guy said to try bouncing it for a bit.
Koa is offline
Old 07-03-2005   #6
Trader Rating: (0)
I remember when i once ran out of petrol, when the AA turned up they pointed out you really need to turn the engine over for ages, to get the fuel from the tank to the engine. Afterall the lines etc will be dry, so it might take some time for pressure to build up enough to draw the fuel through. Problem there is you won't do it with just the standard battery, you'll need s jump starter pack or another car jumped leaded to your car.
Then when fuel is through to the engine, you might need to remove the plugs and dry them if they are flooded, alternatively wait until they've dried naturally.
Plus there is the problem of driving a car empty and the effects it will have on the CAT. They don't like it when you run the engine dry and use the last of the dross in the petrol tank.
53 plate, Stilo 3-door, Sassy grey, 17" Claw Alloys, Falken Ziex Z512 tyres, 1.2 Active -- 45mpg!
StiloBoy is offline
Old 07-03-2005   #7
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
dont touch the throtle when you try and start it, turn ignition on untill you hear the pump prime its self then off again, a few times before you actually turn key fully to turn engine over.
Binki
dave is online now
Old 07-03-2005   #8
Trader Rating: (0)
Thanks guys
I'll try out your ideas and let you all know how it goes
Thanks again
res1492 is offline
Old 07-03-2005   #9
Trader Rating: (0)
y not just call the AA? it is included with the fiat w'tee,may as well use it!
still luv my 5 door!(but am starting not too)
still_S.L.Y. is offline
Old 07-03-2005   #10
fixitagaintomorrow's Avatar
Trader Rating: (0)
fixitagaintomorrow has donated! United Kingdom
You could try chucking a couple of gallons more fuel in to see if the pump would catch prime - assuming you can get to a petrol station with a can!
Pete, Clubcento technical bod.
Links: turbo cinq, Bravo/a/Marea owner's club, Clubcento
fixitagaintomorrow is offline
Old 07-03-2005   #11
Trader Rating: (0)
Im not up on the lingo yet
Whats a "W'tee"?
res1492 is offline
Old 07-03-2005   #12
Koa
Koa's Avatar
Trader Rating: (4)
Whats a "W'tee"?
I think he means a Warranty
Koa is offline
Old 07-03-2005   #13
Trader Rating: (0)
Ahhh thanks KoArAnG
Doh...!!
Well i have just been and tried to start my car again and guess what?....... it still didn't start so i tried pushing off the curb and hey-presto it started.
I think i was just panicking last night.
But thanks for all your help guys.
Mucho Grassie-ass.
res1492 is offline
Old 07-03-2005   #14
Italian Stallion
Trader Rating: (0)
twincamms has donated! United Kingdom
Smile The motto of this story is...............................
don't let your car run out of fuel, be like Uncle Twincamms and never let the gauge go below the halfway mark!
twincamms is offline
Old 07-03-2005   #15
Trader Rating: (0)
Re: The motto of this story is...............................
Heheh
The motto of this story is...............................Dont let your brother lend your car
res1492 is offline
