The relay in the rear fuse box, two wires slot in underneath that relay and they are black/green & light Blue/Yellow but can not locate these in the front of the cars fuse boxes
Red
Black/Grey
Red/Black Thick
Yellow/Red
Yellow/Blue
Red/Black
Grey
The fuses are both fine, the black/green wire should connect to point 86 of the relay
It's a pickle to get the seats to work as I spent too many hours tinkering around and found that you have to connect one of the two can lines from the seats to the body computer for them to work, my car is a 1.8 dynamic and the memory seats and mirrors work perfect with no need to change any parts, it caused problems at first but just read the manual
don't know if i've missed this, but where did you put the wire in body computer?
or does it not matter,
Hi all,
Having both my boyfriend and I reading the full thread we are still ignorant of what goes where
We have connected a single can line to the pink and white wire in 'the brain' and that didn't work. So struggling to decifer what thread #37 means, we tried it with both can lines and yet again nothing.
The pos and neg are connected to power btw.
Please can you help and tell me what we're doing wrong.
About to give up and I only have a few days before I need use of my car again. Short of calling an auto electrician out, I'm baffled!
cheers
In relation to "both can lines" I meant one can line from each of the seats instead of both and the pink/White can lines were needed to be connected and these were connected to the fuse box under the steering wheel off the right connector of the three that are there and it's the only pink/White cable there.
If anyone needs telling 'in detail' how this was done please PM me
Tar
The Light Blue/Yellow (Yellow/Blue in your list?) wire comes from ignition activated relay T12 via fuse F52, (both in the dashboard fuse box) and goes to terminal 85 of the large square relay T21 in the rear fuse box. Switching the ignition on activates relay T12 which in turn activates relay T21.
You say it should connect to pin 86. If it does connect to pin 86, then it's the earth wire for the square relay operating coil. It connects to the passenger side front earthing point C20 along with the 3 of the 4 black wires from the seat connectors.
As it's a permanent earth, you could connect it to any earthing point on the car. (The bolt that holds the rear earthing point next to the rear fuse box for example).
Thankyou for the advice Davren; much appreciated. I managed to get everything hooked up, the electric seats so they now move back and forward - however do not heat. Could this be down to the blue and yellow wire not being connected ?Re. the thin Blue/yellow wire. Labeled AG in the wiring diagram.
From post #42 above:
Re. the thin Black/green wire. I believe this is the wire that's incorrectly labeled NZ (Black/purple) in the wiring diagram.
From post # 48 above:
