The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 09-07-2006   #61
Glutton for Punishment
Rich's Avatar
Trader Rating: (1)
Rich has donated! United Kingdom
Re: How to install Connect NAV+ to Fiat Stilo 1.6 Dynamic
Right, wiring for CN+ is practically done; the timer delay we made works perfectly, and cost a total of £12. Took the earth from the main stereo earth and the +12V ignition from the air con panel; took the wrapping off the loom and re-wrapped everything up so it all looks original. Microphone feed is in there too, and the GPS/GSM wiring is almost done (done "My Car" to Sat Nav, and the other end goes from "My Car" to the boot, where it's waiting until I get an antenna and we'll put it together).
Has anyone who has retrofitted this found a cheaper way of doing the microphone and antenna, or is it another £200? Noticed the Lancia Ypsilon has a similar microphone part to the Stilo: Stilo's is £45, Ypsilon's is £4.10!!!
07 Bravo TJet Sport, Maranello Red
Factory Options: Dual Zone Climate, 18" Alloys
Retrofitted: Armrest with conditioned foodbox, Stainless Kick Plates
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Rich is offline
Old 11-07-2006   #62
www.ukpolicef0rum.co.uk
robertk2003's Avatar
Trader Rating: (0)
robertk2003 has donated! United Kingdom
I'm just going to be a duffus, and ask, All this "Installing your own CN+" Are the instructions for installing it to cars with DZ Climate control or to cars with just Air Con?? I know i'm a duffus but heeey
Weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeee
robertk2003 is offline
Old 11-07-2006   #63
Rich's Avatar
Trader Rating: (1)
Erm it doesn't make a blind bit of difference if it's Air Con or Climate Control, will go in ANY Stilo
Rich is offline
The following user says "Thank You!" to Rich for this useful post:
johnson550 (17-09-2008)
Old 23-07-2006   #64
Rich's Avatar
Trader Rating: (1)
Now up in the Guide Section, am editing as I go, should all be fully complete soon. Has some background information if anyone is thinking of fitting the unit to their Stilo . . . it's not as scary as it sounds though!
Rich is offline
Old 21-08-2006   #65
Rich's Avatar
Trader Rating: (1)
Another bit of news . . .
Not wanting to spend the £45 on the Stilo microphone, I tried many others to no avail (all free). So, I thought I'd bite the bullet and buy it.
However, being clever (), I searched ePER one night and noticed that the same trim part on the Lancia Ypsilon where the microphone goes on the Stilo was £3.80, with the (263,903,904) CN+ options. For the sake of £4 I thought I'd order one.
It arrived this morning, and apart from being beige and not grey, is identical to the Stilo microphone and trim we ordered for the Schumi. So, having already got the header console with Alarm sensors, I took the microphone from the Lancia part and installed it in mine; car is at the dealers as we speak so I will be testing it later.
Parts Manager reckons it's a c**k up on the parts prices, ooh yeah
Rich is offline
Old 24-08-2006   #66
Trader Rating: (0)
Does anyone have a Connect/Nav+ up for sale, or know were to get one?
casperskj is offline
Old 30-08-2006   #67
Trader Rating: (0)
Hi, im trying to adapt a nav+ of alfa brera 2006 in my fiat stilo jtd 2003, i found some problem, when i conect the 12v+ that is needed to the activation, the sistem ask me for the code, i put the original code, and the sistem shows "configuration of your car is not avaiable" and the sistem dont shows velocity, consumption, km done, etc... but if i change somthing like the language, the sistem changes in the car and in the lcd of the dashboard the language too...
somthing have changed his gps for other compatible car?
im getting crazy to do that the sistem works
thanks a lotĦĦ
gonzalo, a member of club fiat stilo spain --> www.clubfiatstilo.com
ervirux is offline
Old 10-09-2006   #68
Rich's Avatar
Trader Rating: (1)
Woo, my unit is now completely in and antenna installed .
Installation guide also now finished!
Rich is offline
Old 08-06-2007   #69
Trader Rating: (0)
Netherlands
Talking Re: Connect Nav+ Installation
I found an easier way to connect the switched +12V from pin 4 / connector A:
remove the inner lining of the upper glove compartment (2 screws) - on the left (right side of the Connect system) there is a white connector with a lightblue/green stripe lead. This is the switched power for the air recirculation switch and is on a very short distance from the connector of the Connect system! It has already a fuse of 7.5A which is a good value for the Connect.
I tested it and it works 100% reliable !
The instrument cluster doesn't have to be removed in this case.
good luck,
yellowstilo
yellowstilo is offline
Old 09-06-2007   #70
Trader Rating: (0)
Netherlands
good luck,
yellowstilo
Oops - I just realized that cars in the UK have the (upper) glove box on the left side - so I guess the connector might be on the left side of the Connect unit in that case ??
Old 13-11-2007   #71
Trader Rating: (0)
where i must connect a microphone ?? can you make a foto to wich pins i must connect them ??
PiotrPietak is offline
Old 26-12-2007   #72
Rich's Avatar
Trader Rating: (1)
Going to be doing this for the 4th time soon, and we've come up with a way of saving a few quid again.
If you purchase the GPS/GSM antenna from an Alfa 159, it comes with enough cable to take you to the back of the "My Car" panel, pre-wired. This'll save you the £55 for the "mid-section" loom. The aerial itself is £85 cheaper so thats £140 saved .
Rich is offline
Old 06-01-2008   #73
Trader Rating: (0)
hi im new here.and i have a stilo 1.6 and i have a nav.in abarth ans i what to change to 1.6 but i dont no how to get out nav.but in 1.6 its to esy.thanks
stanko is offline
(G) New Fiat Stilo Schumacher Limited Edition apierdomi Stilo 25 11-09-2004 20:32
Connect Nav - How do I Play[?] Gladiator111 Multipla 1 06-07-2003 00:22
Fiat recalls - Seicento Stilo Ulysse [3] roby76it Lets Talk FIAT 0 14-04-2003 02:57
