The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 28-10-2008   #31
Davren's Avatar
Trader Rating: (0)
Davren has donated! United Kingdom
Re: Stilo Heater
I'd be interested in the outcome of this too, I have exactly the same problem with the climate control on my Stilo JTD. Passenger side works perfectly but the driver's side will only blow cold.
If it were the pollen filter, it would affect both sides equally so I don't think that can be the cause.
I suspect it's going to be something to do with a flap or actuator motor within the heater casing but it doesn't bother me enough yet to start pulling that apart.
Dave.
If all else fails.. read the instruction book.
Davren is offline
Old 28-10-2008   #32
Trader Rating: (0)
Re: Stilo Heater
Hi All
I have had this problem for some time now I found if you keep fiddling it will eventually start working.
The best way I found so far is to set to mono and run the temp to cold then back to hot switch off engine restart do the same again, bit of a pain but mine seems to work O.k. most of the time now.
Good luck.
P.S
I also noticed that the driver’s side foot well vent actually diverts the air up under the dash, so I cut the fins out works o.k. now.
cris1117 is offline
Old 29-10-2008   #33
popping out
dan-the-man's Avatar
Trader Rating: (0)
dan-the-man has donated! United Kingdom
Re: Stilo Heater
I think it's called the tempreature control flap which will be your problem.
It's a b**tard to fix as you have to take most of the dash out to replace it, dealer tried fixing it me by gluing it on for £96 broke again after about 1 week.
dan-the-man is offline
Old 29-10-2008   #34
It's about GO! not SHOW!
Argonought's Avatar
Trader Rating: (0)
Argonought has donated! United Kingdom
Re: Climate control - cold air only on drivers side?
Just done a merge on this - as it come up before.
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic
Argonought is online now
Old 06-11-2008   #35
Stilatos's Avatar
Trader Rating: (0)
Greece
Grrrrr seems like my poor stilo is falling apart slowly lately. Now that its getting cold here and i start using the heat i have the same problem the drivers side is cold and the passengers is fine. i tried to do the relearning process but doesnt really work only if i turn off the car it fixes for a bit. Also noticed that last year i would put the heat to 20-22 and got decent heat not too much now to get the same mild heat i have to put it to 26. Very weird stuff.
1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr
Stilatos is offline
Old 11-11-2008   #36
NobodyBlamesTheHappyGuy:D
Morty Mort's Avatar
Trader Rating: (1)
Morty Mort has donated! Norway
Well, Stilatos. Mine has now the same problem. Cold air isn't coming at all. The clutch engages, but the only way of getting outside temp (which now is pretty low) is to set it to "lo". No aircon though, despite the snowflake is on. This is a problem as the car fogs down when all wet and damp people enter the car.
The problem has occured a couple of times earlier, but then it has only needed a restart. Now it is permanent. Where is this flap everyone is talking about? We have lefthand driven cars so it might be easier for us to access the area, but I really haven't done more in that console than refitting the pollen filter - which is a doodle, as there are no obstaclin' pedals.
Or is it an electrical issue with this flap? The fan works like hell, so the fault is most likey after the fan.
Can someone point us in the right direction? I will not dismantle any dash!
Morten.
jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint.
member of the 5-door massive attack.
Morty Mort is offline
(T) climate control only blowing cold?? wsty Stilo 2 11-10-2008 12:37
Climate control/air con clair80 Panda (New) 11 11-07-2008 13:00
Air con or climate control? Rustbucket Barchetta 5 01-04-2008 21:51
(G) Help with Air Con/Climate Control Gusfiat 500 5 31-03-2008 16:49
