Thread Tools
Old 27-08-2010   #1
How do you change a rear brake light bulb?
help!
Thanks,
Matt
Swivel is offline Reply With Quote Quote
Old 27-08-2010   #2
Re: How do you change a rear brake light bulb?
Take out light cluster....
Remove Brake bulb....
Change....
Replace.
Mr Cousins is offline Reply With Quote Quote
Old 27-08-2010   #3
jackson74 has donated!
Not quite that simple. Can be a bit of a mare accessing the nuts at the back of the cluster via the small removable panel in the boot liner, almost guaranteed you'll lose at lest one whilst unscrewing or replacing them!
jackson74 is offline Reply With Quote Quote
Old 27-08-2010   #4
Ah just seen that, gone are the days of removing the boot liner like in the coupe and seeing the back of the light! Thanks for the heads up i'll get on it now
Old 27-08-2010   #5
Driver Extraordinaire
minimad99 has donated!
LOL, this is a job I've tackled recently and found it easiest to actually get into the boot and use a socket on an extension bar to gain access.
Why oh why do Fiat make things so complicated, especially changing bulbs!!!
minimad99 is offline Reply With Quote Quote
Old 27-08-2010   #6
Why dont you just use the little tool in the spare wheel kit? Little black/red thing that locks onto the bolts so you dont loose them?
Old 27-08-2010   #7
disconnect the electrical connection first, then then unbolt and remove cluster, then unscrew the plastic cover and change bulb, then reverse the order!! pain the neck it is.
04 Stilo, 1.4 16v 5dr
Sticking feathers up your butt does not make you a chicken
roboticgimp is offline Reply With Quote Quote
Old 27-08-2010   #8
Andymacselespeed has donated!
Quote Originally Posted by minimad99 View Post
Because they want you to go to the dealer to get the bulbs changed, its a cash cow, same for front bulbs. Same on many modern cars. Should be a legal requirement that all main bulbs can be changed at the roadside with onboard tool kit.
My old A4 had a really clever way of changing front bulbs. Two bolts on the lamp release the whole assembly, pull it out, unclip the back covers, change the bulb, bolt back in. The whole operation takes 5 mins, and is included in the manual. Fiat says - Consult your dealer for service. Grr
Alfa 156 GTA SW 250bhp of Italian goodness!
Andymacselespeed is offline Reply With Quote Quote
Old 27-08-2010   #9
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Bolivia
Quote Originally Posted by Andymacselespeed View Post
To be fair though I can change front and rear bulbs on my Stilo with my onboard tool kit, and its only a small box I carry
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
2 White Classic Panda Selecta's, 1989 Panda 750L,
2013 Toyota Prius Plug-In & 2009 Panda Eleganza
Most Easterly Pandas is offline Reply With Quote Quote
Old 27-08-2010   #10
Aye, but its a pain in the backside to do. Should be simple, there should be an easy way to get at the bulbs. I mean on the back of the stilo, why not have a fixed lens cluster, and the light bulb panel as a simple clip in unit behind the trim in the boot. Then changing a bulb would be a simple job, reach in, unclip the panel, remove the blown bulb, replace with new clip back in. Done. Hey hoo, when I rule the world!
Old 02-09-2010   #11
Sunny Durban is the best.
gerhardj has donated!
South Africa
I did mine not to long ago. Search the threads I took some photo's of the process and put it up.
gerhardj is offline Reply With Quote Quote
Old 25-01-2012   #12
I know this is an old thread but thought this might help others.
Like others here my big hands just do not fit. I could get the bulb out but not get it back in. I could not find the red Fiat tool so I resorted to a philips screwdriver. Simply pull away the rubber door seal then remove the 3 philips screws on that little plastic shelf where the seatbelt comes out and the 1 screw holding the door lining. You do not have to remove the shelf at the top, just those 3 screws so it is nice and loose. The with a quick tug you can pull back the carpeted lining to give you plenty of room to access the cluster.
While this may sound complicated it took me under 2 minutes to change the bulb and put back the screws.
phill104 is offline Reply With Quote Quote
Old 27-01-2012   #13
I do think it's ridiculous how hard they make it to change them. The front n/s bulbs are the biggest pain. It really should be user serviceable at the roadside, it can be pretty dangerous otherwise. I can barely manage to change them in full daylight, never mind at the side of the road at night! Should be as simple as unclipping the assembly, popping it out through the front, changing the bulb, putting it back.
kiopo is offline Reply With Quote Quote
Old 28-01-2012   #14
Trader Rating: 2
Bolivia
Quote Originally Posted by kiopo View Post
Perhaps you ought to own a Megane
Likes kiopo liked this post
Old 05-02-2012   #15
They are not too bad compared to some. I got stopped by the rozzers once as I had a rear light out on a Vectra estate. To change it was 20mins work with a torx driver.
The next week a mate at work took his Astra to the garage as a front light was out and was told by the main dealer that it would take 2 hours as they would have to remove the whole light unit. The main dealer had obviously not read the manual as when he came back to the office still with a faulty light as they could not fit him in that day I did read the manual. Turns out there is a flap in the wheel arch, took 5 minutes to change the bulb.
Thread Tools
Rear License plate light bulb change?? pessomar Lets Talk FIAT 4 20-05-2014 01:05
(G) how to change driverside rear dim light and brake light fatwing Multipla 2 01-04-2009 10:24
(T) how to change rear light bulb on doblo 1.9 jtd fiatfred Doblo 13 31-08-2008 23:31
