Always happens when you could do without it. I do only a fifth of my normal mileage over the last month and no issues, due to do about 1500miles in the next 9days and now this has happened.
Patches of oil under the car, N/S, not engine oil, but cleanish so I assume gearbox oil, not jacked the car up, but under tray is covered, sprayed rearwards all up the subframe from driving it like it I assume. And common gearbox leaks on the 6speed 1.4?
Just hoping its a quick and not too costly fix. I've had a look at inner CV boot on gearbox / drive shaft through the alloys and it looks clean and dry so I don't think its that which has split.
Jon
Jon
