Hi all!
After a very happy stilo motoring across France for two weeks
On starting her up in order to drive off the ferry back to Blightylast night; i get the dreaded 'beep beep beep' and a simple message saying "Loose Connection" the car however drives perfectly except for the speedo doesnt work and a yellow ! in a triangle, the abs light and the handbrake lights are also permenantly on.
So i pull over at the nearest services and get on the trusty Fiat Forum on my phones internet, as always I found much to be getting on with while I waited 2 hours for the RAC patroll. Sadly neither he nor I were able to fix it.
He plugged it into his code reader laptop giving the code:
U1706 'CAN Brake Control Node Intermittent'
after a few clearings and tinkering this then changed to permenant.
Between us so far we have thoughly which I checked twice today back home and after much more forum seraching:
Cleaned D4
Cleaned ABS M50 connector
Cleaned Both ECU Connectors
Cleaned C12 ABS Earth
Cleaned ECU and Battery Earths
Checked and cleaned all fuses and relay conenctors in the engine bay
Checked battery charge and charging
Checked battery earth
I have also been follwing one of Decks guides to HSSB regarding how to check D4 connector by checking the resistance between
M50 pin 40 to ECU Socket A pin 61
and
M50 pin 24 to ECU pin 45.
Sadly both of these came up with a very high resistance (off the scale) so I was wondering if the wiring diagram Decks provided in this guide was the one for a 1.9 JTD 03 reg also?
Also any other suggestions greatly appreciated :worship:
If helpful, the only additional history i can provide is one blown brake light bulb 1 week ago and twice before on starting for 1 second abs failure appeared on the screen and dissapeared immediatley.
Cleaned D4
and
