Hello Guys,
I need your help again, I tried searching the forums, but found nowhere someone with problem like mine. I'm desperate and need someone to tell me where might the problem might be.
I have this awful knocking that sounds like it is coming from the pessenger side of the car (left hand drive) when driving over small bumps. It is hard knocking almost metal banging some times. I can re-create the noise if I'm stationary and I shake the wheel left - right several times, this way I can hear the knocking from inside the car.
Now what I have changed so far without success: changed the two front wishbones, changed the track rod ends, changed the steering wheel box (not changed actually it was rebuild as new by my mechanic), changed the front shocks with new FK-Automotive sport shocks, changed the springs with EIBACH sport lines. I even thought the banging can be coming from the back, so I changed the rear bushings, but no luck again.
Still the stupid car is knocking like mad on bumps I have changed almost everything and I'm tired of that.
I really can't seem to find from where the problem might come, my mechanic is also helpless, everything is new and the car still knocks.
Could it be coming from the brakes, and the pads? Is there something that can break or worn in the steering mechanism inside the car near the steering wheel ?
The problem is not also in the torsion bar bushes, as the car is not knocking over speed bumps or whatsoever.
Please help me with ideas.
Thanks in advance for your answers
