Hello
Been learning alot about servicing selespeed on Alfa forums.
They raise a question.
The push rod distance on alfas selespeed should be 28.5mm (on MAR, engine off). Any value much outside of this causes selespeed to be lumpy, hard, not smooth.
Is our selespeed distance the same? I figure DeckChair probably has the answer as always
For example, mine is 15mm which is way off, supposedly.
You can read it on FIATECUSCAN under "Clutch Pedal Position"
