Still the same problem as in it still blows a fuse?
Which fuse is blowing? F16 when T10 85 earthed
If you put 12v power on t10 pin 87 the fuel pump runs yes? No, but if I measure the voltage between pin 87 and live, I get a +12v
I cant even use my Fiat Examiner on the vehicle as it cant connect the the body computer!
Why not? Do you still have that problem of no 12v power at the BC? My Examiner is faulty
Are you sure the inertia cut off switch I30 is working as it should and supplying a signal to the ecu to supply power to the fuel pump? Replace inertia switch some time ago. However, have tested the following - Pin 1 is showing earth, and pin 3 is showing 6.42v with ignition off and 6.19v with ignition on?
I have done a check list and this is the result, it may help?
Pin 30 of T10 is +12v
Pin 85 of T10 is earth when ignition off and +12v when ignition on
Pin 1 of the inertia switch is earth
Pin 3 of the inertia switch is +6.42v with ignition off and 6.19v with ignition on
Pin 30 of fuse board connector block C is +12v
Pin 11 of fuse board connector block C is +12v
Pin 31 of fuse board connector block C is dead
I did some other tests
T10 relay out, pin 86 with ignition off +0.05v, with ignition on 3.62v
T9 relay out, pin 87 with ignition off +12v, with ignition on +12v
T9 relay out, pin 85 with ignition off +12v, with ignition on +12v
T9 relay out, pin 30 with ignition off dead, with ignition on 0.02v
T9 relay out, pin 86 with ignition off +12v, with ignition on +12v
T9 relay in, all pins +12v
I have bought the retail version of fiatecuscan, I looked for stored errors and there were loads, P1653, P0520, P0201, P0202, P0204, P0205, U1600, P0571, P0230, B1027, B1028, B1029 and B100E. A lot of these may be that I have disconnected a sensor and then turned the ignition on?
I am going to give up on the car soon, what would start of intermittently and then be permanent?
Oh, I forgot to say, the ignition ECU, with the ignition on, makes all kind of buzzing sounds ranging in pitch. Is that normal?
