well... another one with the dreaded fault!!!
ASR Failure / Security . Loose connection, My little stilo is as good as dead in the water.
Was fine until 2 weeks ago but now sick to death of it and cant afford to throw anymore ££££ at it.
Only happens when starting , doesnt matter if hot or cold. can sometimes start straight away but more often then not comes up with the above fault.
So far ive had the ECU sent off , inspected tested , immobiliser removed, so the ecu is ok, (12 months warranty as well! Auto-flash)
Crankshaft sensor replaced with new one. ,
Immobiliser aerial ring connection checked - all connections seem fine (though shouldnt matter now immobiliser disabled)
Battery replaced, D4 connector checked / cleaned - no corrosion, all earths seem ok but have been cleaned to make sure , also all battery connections, ecu connections etc and still cannot get the damn thing to work, Even checked the brake pedal switch, no problems there either yet still coming up with the ASR Failure / Security... . Loose connection,
When i did get it running no recorded fault codes though??!
Though never happens when driving along like many others reported??
any ideas anyone?? as otherwise this is one little stilo going to scrap heap as cannot afford to do anymore to it! and cannot afford for another week of not getting to work! :bang:
