- Jan 16, 2005
- 10,608
- 1,450
Hi guys
Not had much luck in the Punto section with this so I thought I'd ask in a section where they have lots more JTDs
Basically I having problems tensioning my new cam belt. I can't seem to make the tensioner stay at the tension I set. That's with the tensioner bolted fully onto the block. The tensioner is new.
I'm a bit stumped TBH as to why I can't set the tensioner up properly. I have found a pin/dowel on the block which the slit in the tensioner backplate can fit over. Do I use this as a stop for the silver pointer then lever the angled tab to set the tensioner?
TIA
TIA
