Technical Climate Control Problem [and Fixing Guide]
As far as i know the Stilo and Bravo have the same climate control. Can you hear a faint of sound of a motor (or two) starting and stopping constantly with just the ignition on, from somewhere near the passenger side (left side) foot well.
Yep, well, it sounds more like a constant clicking than starting and stopping.
Have a look at this thread from post 4 onwards https://www.fiatforum.com/bravo/353735-air-vents.html it may help. Mine only blew cold air to the passenger side (left side). I changed all three on that side because they become brittle. I can't remember which one is was that had broken first on mine as it was a couple of years ago. Remove the motors one at a time. If the plastic link has broke you will tell straight away when you take the motor off. They are easy to do.
hi guys ? I own a bravo apparently the pieces between actuators are the same as stilo only was wondering the that the defroster actuator also is the Same as it is a pain in ass to remove first wanna be sure it is
  • Like
Reactions: pgk
Gentlemen! I tried to find if anyone has just shared this before, but google didn't give me hits from fiatforum.com so here we go (hopefully for the first time):
Someone (a bright guy!) just remodelled the "brilliant" OE part (46723463), 3D printed it and now sells for 5.5 GBP! Here is the eBay link:
https://www.ebay.com/itm/Lever-Ferr...ash=item2399c7cb9f:g:eP8AAOSwd1lagGSK&vxp=mtr
I hope it can be useful for you guys too, and sharing something like that is not against the forum rules...
