Hi -
Need to put new discs on the back end of my trusty Stilo. Is is possible to slip the discs on and off without removing the caliper mount bracket, or does that have to come off too?
Also I have a sticking n/s caliper at the back - I have cleaned & reassembled the assembly 3x without improvement - the rubber seal has a visible tear, so I'm assuming that corrosion or grit is preventing the piston from relaxing it's grip, and that a recon unit from Budweg (thanks PNL) is the way to go. Any comments or advice about that procedure would be appreciated.
(NB - seems the recent bad weather has taken it's toll on rear brakes - never seen so many posts on that subject...!)
