V Vento Patron member Joined Apr 23, 2011 Messages 105 Points 19 Nov 18, 2011 #21 Vento said: There for you need a length of approxemately 20 cm threaded bar e.g. M12, with nuts of 17 mm. Good luck Click to expand... Sorry, has to be M10, with nuts of 17 mm.
R ramborobert Member Joined Aug 7, 2010 Messages 356 Points 64 Mar 19, 2012 #22 I wish I'd seen ur idea on Saturday I think this would work but is there a chance you could damage the wheel bearing? I tried the bolt method with no luck. It is booked into garage on we'd wondering if I should try this first.
