Technical Connect Nav+ Master code request
Пробвах не не се получава(сега е с версия 8,3)във какъв формат да се запише дискът с версия 9,8.опитах в cd iso но не става
успях стана а даже си е на англииски
"in which format to save disk version 9,8."
Download CN98.RAR from the link I gave you, then unzip it with WinRar. That will give you a file named CN98.ISO. This is an image file. You must use the image file to create a disc, not burn the file to disc.
"It became and even is in the foreign language"
After you have updated to version 9.8, you can use the Setup disc to change the language back to what you want. You can download the Setup disc from here: https://www.fiatforum.com/downloads.php?do=download&downloadid=417
All the instructions are in post 2 of this thread: https://www.fiatforum.com/stilo/343881-connect-set-up-cd.html?p=3419564
има само 1 проблем когато изгася CN+ ,бутоните оставят да светят и се чува звук от вентилатор за охлаждане.
"there is only one problem when extinguish CN +, the buttons remain lit and sound of the cooling fan"
If it is too hot inside the CN+, the cooling fan will stay on after you switch the CN+ off. I do not know if the button lights stay on with the cooling fan.
If the cooling fan stays on when the CN+ is cold, then it could be a problem with the temperature sensor. I have never seen a separate temperature sensor inside a CN+, so it is probably part of the main processor.
Аз мисля че не-изгасва CN+а само заспива ,след като натисна отново бутон ОN CN+започва да работи от където е свършила ,няма началният син екран с логото на fiat, мисля че само заспива а не изключва,и черпи ток ат акомулатор(батерията)и после проблем със стартирането на автомобила
"I think that no-goes CN + only sleep after pressed the button again ON CN + starts running from where it ended, no initial blue screen with the logo of fiat, I think it just falls asleep and not off and draws current AT akomulator (battery) and then a problem with the launch of the car"
You may have a problem with the power supplies to the CN+. It should have a permanent power supply and a second power supply that is switched by the ignition key.
"i think that no-goes cn + only sleep after pressed the button again on cn + starts running from where it ended, no initial blue screen with the logo of fiat, i think it just falls asleep and not off and draws current at akomulator (battery) and then a problem with the launch of the car"
you may have a problem with the power supplies to the cn+. It should have a permanent power supply and a second power supply that is switched by the ignition key.
Да вярно благодаря че ме подсетихте вторич+ при мен е захванат от първият и затова cn+работи без контакт ,ще захвана от контактключ и ще пиша за решението,благодаря
Всичко е ОК просто хванах втори + от запалката на колата
Здравейте, можели малко помощ как да свържа камера за заден ход на cn+,какво ми трябва за монтажа,искам да направя нещо подобно,
какво ми е необходимо за да вкарам видео сигнал(да изкарам картина )на екрана
help please
i need master code for ****ing cn+
I bought a broken car only for navigation
I connect it to my car and asks me master code
imei 500189440217620
51yc02213 b03
help please,
There are several ways to get the code for CN+ units.
If it's a new unit, a Fiat dealer can get it from ISR using the registration number of the car it was originaly fitted to. I got one using this method for £15 (GBP) but prices vary according to dealer.
If it's a reconditioned unit, Fiat dealers can get the code from Magneti Marelli using a high definition photograph of the barcode label on the unit. Some dealers don't know they can do this (or don't want to) but there was a service bulletin issued several years ago explaining it. I got 2 using this method for £35 (GBP) each.
Most expensive way is to send the unit to MM in Italy re. this e-mail I received from MM a few years ago.
Sent:Monday, March 02, 20093:40 PM
To:
Hello Mr XXXXXXX
For the issue of master code you have mentioned, the CONNECT system on your Fiat Stilo must go to Magneti Marelli laboratory, only in this way MM can found the master code.
The cost is 145 Euro.
You will incur the expense of the transfer to Italy, where as to transfer back will be to our expense.
The payment will made via bank transfer to Magneti Marelli.
Address MM laboratory: Auconel
Viale Kennedy 230
10040 LEINI’ ( TO)
Italy
INFORMATION FOR BANK TRANSFER
Fiat Finance S.p.A / Magneti Marelli After Market Parts & Services S.p.A.
Banca Intesa San Paolo S.p.A
Rete Banca Intesa
Via Alfieri, 6/8 – Torino
Swift : BCITITMM824
IBAN : IT02 M 03069 01110 000003585070
_______________________________________
Claudio Brusa
Service Network - CallCenter
Magneti Marelli
After Market Parts and Services S.p.A.
www.magnetimarelli-checkstar.it
Its seems the link you gave to the 9.8 doesn't work anymore.. Do you have a new link to update my connect nav to 9.8?
thx in advance(y)
Hi, this by example...
224174-connect-nav-master-code-request-3
But zeewulf just gave me the right link...many many thanks!!!!!
so if you conect the can A and then the can B it won't require the master code?
Hi,yes i now for the delay and it isn't problem already for me. Thaks for link with instruction for install,I even found another one :
https://www.fiatforum.com/stilo/25227-how-install-connect-nav-fiat-stilo-1-6-dynamic.html, but I don't know what to do with Master Code,and can't use services of local fiat dealer. What can say about this:
All you have to do, is to connect the CANBUS A-Line first, after that connect the CANBUS B-Line. With this you override the Mastercode on the CN+."
and this :
The thing with the can bus lines is correct though. works exactly that way
