kayaker-ant
Hey guys,
a new one for you, had a look around and couldn't see anything that matched my symptoms on here. I have a 1.9Jtd 115 MW, When setting off more times than not now if I drop the clutch in normally it takes around 10 seconds for it to get above about 10mph unless I rev it to over 3000rpm before dropping the clutch and even then sometimes it just dies when I drop the clutch in, it usually only happens in 1st gear and once I'm above about 20mph it seems ok but last night it really struggled in any gear and I was having to rev it like hell to get any kind of normal speed out of it. No warning lights are showing or errors coming up other than the usual Pre-heat fault that has always come on.
I'm thinking this is an engine management issue but as I'm not familiar with diesels I'm not really sure where to start?
Cheers, Ant
Cheers, Ant
