| | #76 | ||
Posts: 2,305 Thanks: 284 Trader Rating: 0 | Re: FREE Fiat diagnostic software Currently no, but if you post a request for it on yani's website, he may be able to add it.
| | #78 | ||
Posts: 26 Thanks: 1 Trader Rating: 0 | Re: FREE Fiat diagnostic software I have been using this software to diagnose the ecu on my dads stilo 1.6 16v. I am using the v1.6 and it works a treat! Got an VAG obdII cable from ebay to use This software is highly recommended and commended Thanks Yani Flyright
| | #79 | ||
| I Can Haz Titlez Join Date: Feb 2007
Posts: 142 Thanks: 10 Trader Rating: 0 | Re: FREE Fiat diagnostic software
| | #80 | |||||
| | #81 | ||
Posts: 26 Thanks: 3 Trader Rating: 0 | Re: FREE Fiat diagnostic software this is what i did to get it to work for me i have read a few posts on people having problems hopefully this will help. my car is a fiat stelo 1.9 jtd 115bhp.after a little help and loads of reading job done. the lead that i used is a usb obd11 diagnostic lead 409.1 kkl vag com from ebay. http://cgi.ebay.co.uk/USB-OBD-II-Dia...74666591029386 the driver that comes with the lead uses normall windows buffers you need to update these from here LATEST FTDI CDM Drivers 2.06.00 http://www.ftdichip.com/FTDrivers.htm THATS IF YOUR LEAD HAD THIS CHIP INSIDE IT MOST HAVE. install the new driver and change the latency to 1 as shown in the how to on fiat ecu site. take note of the port number . plug your lead into the car then into the labtop choose your type and make shure you change the port setting on the fiat software turn your key to mar and hit connect. :P
| | #82 | |||||
Posts: 347 Thanks: 24 Trader Rating: 0 | Re: FREE Fiat diagnostic software
as diesels don't have ignition like petrol engines i guess this procedure is not applicable/nessesary for diesel engines? I don't know if they have a phonic wheel at all ?
| | #83 | ||
Posts: 4,163 Thanks: 348 Trader Rating: 0 | Re: FREE Fiat diagnostic software Up until now I haven't had time to try the program out but I plugged it in this morning and it connected straightaway with no need for new usb serial port drivers. Excellent program Yani In fact, it's looks like I have a problem with one of my ignition coils (No.3) which might save time trying to find out which one it is causing a slightly irregular tickover
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 2 Weeks Ago at 13:20. | ||
| | #84 | ||
Posts: 2,890 Thanks: 58 Trader Rating: 0 | Re: FREE Fiat diagnostic software does any wont know if this software can read engine faults and clear them as the engine management light has come on today (misses 1.2 stilo 2003). Then tomorrow it'll go off - well maybe, its been intermitant for awhile now and I just want to read the fault and clear it and see what it is... Had the RAC out the other year to it and was exhaust manifold gasket or something!!!
| | #85 | ||
Posts: 2,305 Thanks: 284 Trader Rating: 0 | Re: FREE Fiat diagnostic software Yes it does but unless you rectify the fault that's causing the fault code, it will continue to come back.
| | #86 | ||
Posts: 2,890 Thanks: 58 Trader Rating: 0 | Re: FREE Fiat diagnostic software I know... plan on changing the manifold gasket when the weather gats better along with the flexi section and back box... which im sure is the problem as the car runs as sweet as a nut *touch wood* as i say that now!
| | #87 | ||
Posts: 474 Thanks: 16 Trader Rating: 0 | Re: FREE Fiat diagnostic software So my lead has come today and what do i need to do to get it set up on my laptop please, and to use it. Download the software, load the drivers from the disc, update those drivers and then i guess plug it into the car, Where is the plug too please. Now i cant do anything stupid or change anything to the car can i???? Thanks
__________________ One very abused 04 Stilo Multiwagon JTD in Red!!. | ||
| | #88 | ||
Posts: 2,305 Thanks: 284 Trader Rating: 0 | Re: FREE Fiat diagnostic software There's instructions how to set it up on jani's website here; http://www.fiatecuscan.net/HowToUse.aspx It also shows a picture of the connector location on a Stilo but for RHD cars, it's at the top of the fusebox.
| The following user says "Thank You!" to Davren for this useful post: | ||
Muppet1 (1 Week Ago) | ||
| | #89 | ||
Posts: 474 Thanks: 16 Trader Rating: 0 | Re: FREE Fiat diagnostic software Dont quite know where to put this but just been out to plug into the car and there is abot 25,000km's difference between what it says on the speedo to what it says in the diagnostic software. Speedo is reading less. Any ideas as to why this should be and should i be worried.
| | #90 | |||||
Posts: 67 Thanks: 4 Trader Rating: 0 | Re: FREE Fiat diagnostic software
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| | lilcow418 | Punto | 1 | 25-07-2009 18:28 |
| | firkin | Cinquecento / Seicento | 0 | 17-05-2008 22:11 |
| Diagnostic software | Captain Mike | Computing | 13 | 04-03-2008 00:44 |
| Diagnostic software | dan18ro | Tipo | 1 | 17-01-2007 19:54 |
| | RaduPopa | Punto | 0 | 05-01-2006 09:04 |
