| | #16 | ||
| | re: FREE Fiat diagnostic software Sounds good! I'll have to give this a go Would this cable work? http://cgi.ebay.co.uk/UK-USB-OBD-Dia...ht_4641wt_1113Look forward to the next update, Service Reset would be great!
__________________ ![]() FOR SALE: Cinq NEW Brake cylinder, Stilo Door loom, C/L mech, Punto Good tyres, Steering ECUs, NEW Brake cylinder, NEW Coolant pump, Head seals, | ||
| | #17 | |||
http://cgi.ebay.co.uk/409-1-KKL-VAG-COM-USB-OBD2-OBD-II-Diagnostic-Cable-Gift_W0QQitemZ280423568490QQcmdZViewItemQQptZUK_Di agnostic_Tools_Equipment?hash=item414a8c146a
__________________ 2007 Stilo Sporting M/Jet 150bhp 2001 Marea Weekend JTD 110bhp now 171bhp http://www.fiatforum.com/garage_vehi..._vehicle&id=24 He who works and does his best gets his cards just like the rest | |||
| The following user says "Thank You!" to johnson550 for this useful post: | ||
Argonought (12-12-2009) | ||
| | #18 | ||
Posts: 400 Thanks: 37 Trader Rating: 0 | re: FREE Fiat diagnostic software
| | #19 | ||
Posts: 1,770 Thanks: 45 Trader Rating: 1 Drives: | re: FREE Fiat diagnostic software What to expect next: - Airbag SIEMENS MY99 ECU support. Aaaaalright!!!! Is this what's in my Stilo then? High hopes.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | ||
| | #20 | |||||
| | #21 | ||
| | re: FREE Fiat diagnostic software That would be great! Stilo airbags are a common problem (as I have recently found ) so that would be a fantastic feature!I know your software is freeware, but I think you should have one of those paypal 'Donate' buttons on your site. I'm sure plenty of people would be willing to donate a little if your software helps them to trace a fault with their car (I know I would.)
| | #22 | ||
| | re: FREE Fiat diagnostic software You can do Stilo airbags already with SanderQV's KWP71 diag and also alfadiag. No matter what software - you will need to modify your KKL interface to do this. ABS is on Pin1 and Airbag on Pin3 of the diagnostic connector, so if you want to communicate with them you can either merge pin 1,3 and 7 together or fit a switch to select between them. Saying that the interface in this new software is excellent, maybe you could look at taking the data from some of the unidiag/kwp71 definition files and adding them into your program yani?
__________________ If it aint broke, break it and fix it anyway ![]() ![]() '03 Stilo Abarth, 35mm drop, grooved discs and Greenstuff pads, Cupra front splitter, BMC CDA, 17" Claws, Fiat blinds and guess what? No warnings or flashing lights ![]() Last edited by danhans115; 19-11-2009 at 14:54. | ||
| The following user says "Thank You!" to danhans115 for this useful post: | ||
Xen (19-11-2009) | ||
| | #23 | |||
When i search for SanderQV it often refers to Unidiag... are they the same thing? Will unidiag do airbags?
__________________ ![]() FOR SALE: Cinq NEW Brake cylinder, Stilo Door loom, C/L mech, Punto Good tyres, Steering ECUs, NEW Brake cylinder, NEW Coolant pump, Head seals, | |||
| | #24 | |||
Merging the pins together shouldnt cause you problems as the control units attached to each pins have different addresses so you wont get conflicts when they are initialised. See here http://autos.groups.yahoo.com/group/UniDiag/ - if you get stuck PM me.. BTW - sorry for taking this off topic - Back to FiatECUScan
__________________ If it aint broke, break it and fix it anyway ![]() ![]() '03 Stilo Abarth, 35mm drop, grooved discs and Greenstuff pads, Cupra front splitter, BMC CDA, 17" Claws, Fiat blinds and guess what? No warnings or flashing lights ![]() | |||
| | #25 | |||||
Also, speaking about airbags - they use another protocol for communication, so I need to implement it first... Anyway, I will do it, it's just a matter of time...
| | #26 | ||
Posts: 6,426 Blog Entries: 1 Thanks: 244 Trader Rating: 0 Drives: | re: FREE Fiat diagnostic software
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #27 | ||
| | re: FREE Fiat diagnostic software Dropping the FIFO buffers down to the minimum can help with connection issues, it in the driver properties for the virtual com port in device manager. I know Johnson550 has had it going with his mjet sporting, not a non-eobd compliant JTD granted. Make sure the plug is all the way in as well, as the quality of these devices is often a little flaky. To test the serial side is working okay connect the interface to the car, open hyperterminal (at any speed) and if the device is powered when you will get the characters echoing back. If not the KKL interface isnt getting any power.
| | #28 | ||
| | re: FREE Fiat diagnostic software It works on my Marea JTD 110 at least Ive done errors I havent fathomed the rest out yet but it connects up first time everytime.
__________________ 2007 Stilo Sporting M/Jet 150bhp 2001 Marea Weekend JTD 110bhp now 171bhp http://www.fiatforum.com/garage_vehi..._vehicle&id=24 He who works and does his best gets his cards just like the rest Last edited by johnson550; 27-11-2009 at 19:10. | ||
| | #29 | ||
| | re: FREE Fiat diagnostic software My 1.2 does nothing when trying to connect (Bosch ABS 5.7) and then the software gives up. Bridging the pins lets me connect for a brief second before the software says 'Reconnecting,' and at the same moment, the car comes up with ABS, EBD, ASR failure until i unplug the interface. Unidiag works fine straight away but the scaling is well out... can't find a compatible def file for the 1.2 16v stilo
| | #30 | ||
Posts: 15 Thanks: 0 Trader Rating: 0 | erm Ive got a problem with connecting it to my stilo. Ive cable, picked right 'com' the msg is saying connecting to ecu - in bttm left corner its sayin 'connecting...' and after about 10s 'disconnected' what to do?
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| tr1s0 |
| | lilcow418 | Punto | 1 | 25-07-2009 18:28 |
| | firkin | Cinquecento / Seicento | 0 | 17-05-2008 22:11 |
| Diagnostic software | Captain Mike | Computing | 13 | 04-03-2008 00:44 |
| Diagnostic software | dan18ro | Tipo | 1 | 17-01-2007 19:54 |
| | RaduPopa | Punto | 0 | 05-01-2006 09:04 |
