Lamps by Post - For all your lighting needs
Thread Tools
Old 18-11-2009   #1
Bulgaria
FiatEcuScan diagnostic software
Hi guys,
you can check this FREE program for reading ecu errors, reading data, actuator tests, etc.
www.fiatecuscan.net
It supports Stilo JTD engines and Stilo ABS.
Thanks aweh, Shadeyman, Bulletproof Saint, MiroslavSER, Qi1 and 7 others thanked for this post
yani is offline Reply With Quote Quote
Old 18-11-2009   #2
The moneypit has gone....
Trader Rating: 2
danhans115 has donated!
Andorra
re: FiatEcuScan diagnostic software
Johnson550 told me about this the other day - You need a KKL interface, a cheapy vagcom 409.1 cable will do the trick ~13 on ebay. Either than or a homebrewn serial one.
Looks like a good program, just get us some selespeed CFC-209 and ME731 support for us non-sludgeburners.
Thanks Argonought thanked for this post
If it aint broke, break it and fix it anyway
Former Abarth Owner
danhans115 is offline Reply With Quote Quote
Old 19-11-2009   #3
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
What to expect next:
- Airbag SIEMENS MY99 ECU support.
Aaaaalright!!!! Is this what's in my Stilo then? High hopes.
jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts.
member of the 5-door massive attack.
Morty Mort is offline Reply With Quote Quote
Old 19-11-2009   #4
Bulgaria
Quote Originally Posted by Morty Mort View Post
Yes, it is the Stilo airbag....
Old 19-11-2009   #5
Trader Rating: 2
Andorra
You can do Stilo airbags already with SanderQV's KWP71 diag and also alfadiag.
No matter what software - you will need to modify your KKL interface to do this. ABS is on Pin1 and Airbag on Pin3 of the diagnostic connector, so if you want to communicate with them you can either merge pin 1,3 and 7 together or fit a switch to select between them.
Saying that the interface in this new software is excellent, maybe you could look at taking the data from some of the unidiag/kwp71 definition files and adding them into your program yani?
Thanks Xen thanked for this post
Former Abarth Owner
Old 19-11-2009   #6
Xen has donated!
Quote Originally Posted by danhans115 View Post
Brilliant! Need to get to the bottom of this airbag fault ASAP. By merging the pins, will it not affect any other functionality?
When i search for SanderQV it often refers to Unidiag... are they the same thing? Will unidiag do airbags?
Xen is offline Reply With Quote Quote
Old 19-11-2009   #7
Trader Rating: 2
Andorra
Quote Originally Posted by Xen View Post
Unidiag does do some airbags - but not the stilo ones so KWP71 diag works on those. Join the unidiag group on yahoo (its been mentioned on here a few times).
Merging the pins together shouldnt cause you problems as the control units attached to each pins have different addresses so you wont get conflicts when they are initialised.
See here http://autos.groups.yahoo.com/group/UniDiag/ - if you get stuck PM me..
BTW - sorry for taking this off topic - Back to FiatECUScan
Former Abarth Owner
Old 19-11-2009   #8
Bulgaria
I already have the data from another source. It just takes time to add the data for each ECU.
Also, speaking about airbags - they use another protocol for communication, so I need to implement it first... Anyway, I will do it, it's just a matter of time...
Old 27-11-2009   #9
Trader Rating: 2
Andorra
Dropping the FIFO buffers down to the minimum can help with connection issues, it in the driver properties for the virtual com port in device manager.
I know Johnson550 has had it going with his mjet sporting, not a non-eobd compliant JTD granted.
Make sure the plug is all the way in as well, as the quality of these devices is often a little flaky. To test the serial side is working okay connect the interface to the car, open hyperterminal (at any speed) and if the device is powered when you will get the characters echoing back. If not the KKL interface isnt getting any power.
Former Abarth Owner
Old 27-11-2009   #10
Fiats since 1973
johnson550's Avatar
johnson550 has donated!
It works on my Marea JTD 110 at least Ive done errors I havent fathomed the rest out yet but it connects up first time everytime.
2007 Stilo Sporting M/Jet 150bhp
2001 Marea Weekend JTD 110bhp now 171bhp (Gone but not forgotten)
http://www.fiatforum.com/garage_vehi..._vehicle&id=24
He who works and does his best
gets his cards just like the rest
johnson550 is offline Reply With Quote Quote
Old 29-11-2009   #11
Trader Rating: 2
Andorra
The author has released a new version, might cure some problems?
Quote Quote:
11/29/2009 - Version 1.3 - Added Magneti Marelli IAW 4AF/4EF/59F/5AF support
- Added Magneti Marelli IAW 49F support
- Added EDC15 support for 2.0, 2.3, 2.8 engines
- Rebuild user interface. All functions are accessible through keyboard shortcuts.
- Added interface latency detection.
- Improved communication protocol, more stable connection.
This is shaping up well by the looks of things, just Motronic 731 please please please
Former Abarth Owner
Old 01-12-2009   #12
has pooped his pants
Greggers's Avatar
Greggers has donated!
Hi guys,
I've had a trawl through the forum trying to get an idea of what's now available for reading the Abarth ECU's but I'm struggling a bit as things keep changing all the time.
Could someone give me a brief "heads up" of what software can do what with the Abarth engine ECU and Selespeed ECU? I've just ordered a 10 VAGCOM KKL cable and I'll see what's what when it arrives...
I really want to control the Selespeed ECU so I can carry out tests once I swap my Selespeed reservoir...
Cheers!
'02 Stilo Abarth 5 Door
18" OZ Wheels, Prodrive GP Suspension,
Brembo Gran Turismos, GTA Injectors, GSR & BMC CDA, Red-Dot Remap, Custom De-Cat Exhaust
Garage
Greggers is offline Reply With Quote Quote
Old 01-12-2009   #13
Trader Rating: 2
Andorra
Quote Originally Posted by Greggers View Post
Hi guys,
Cheers!
Theres nothing mate, not at the moment. I have a *cough* special copy of alfadiag which will talk to the ECU, but the actuator tests and calibration routines dont work on the CFC-209 thats in the Abarth(alfadiag supports just the CFC-208, and 218), and the author of Alfadiag says he has no plans to support it either.
To use alfadiag you just need the cheap KKL cable that you have got. It think as it stands alfadiag is as good as it gets, does ABS, ECU, will get DTC's from the selespeed ecu and does the airbags as well.
The real deal costs 60EUR though, not too bad and a 1000x better than Gendans italiacheck.
Thanks Greggers thanked for this post
Former Abarth Owner
Old 01-12-2009   #14
Greggers's Avatar
Cheers for that Dan, it's gutting about the Selespeed ECU... I'd really like that. I'm loath to do any work on the reservoir myself without being able to run the Selespeed actuator through it's paces once I'm done I don't want to have to pay a garage to change the reservoir either...
Garage
Old 01-12-2009   #15
Bulgaria
Actually, I plan to add selespeed support to FiatECUScan.
It is not a problem to add support for the CFC-209 version as well. It is a very rare unit. I see in my source data that it is used in Stilo Selespeed only, and that explains why noone has plans to support it.
I think I can add support for all selespeed verisons in my program at the end of this month or beginning of January.
Thread Tools
yay ! FiatEcuScan software is looking good.. stylers Tech Talk 6 11-09-2014 11:30
(G) FiatECUscan diagnostic tool topwally Multipla 0 02-05-2010 09:54
(T) Delphi Electric Steering Punto Mk2 with 'Fiatecuscan' diagnostics software Keithn Punto (Mk2/2b) 9 27-04-2010 20:40
(T) FiatECUscan diagnostic tool joipalli Multipla 1 27-04-2010 03:19
Diagnostic software Captain Mike Computing 13 04-03-2008 00:44
