Having major issues with my 52 reg Stilo 1.6 petrol.
Here are the facts...
Engine juddering/misfired/erratic rpm prior to cutting out whilst both going along foot down and stationary (waiting to join roundabout) until it finally cut out for good on a slip road.
Luckily I have AA cover and the chap that came out was very helpful. He spent at least 1 hour with me trying things before I opted for a tow home.
Fault codes are:
P0571 - brake pedal switch
P0420 - Catalyser check
U1702 - CAN network
P0230 - Fuel pump CIRCUIT
He cleared the codes and started the car and the 4 exact same codes reappeared after idling erratically for 5-20 seconds.
He had a few problems with the key/lock light in the dash coming up and not letting him start the car - but he locked and unlocked the car a few times i guess to tell the immobiliser that he isn't nicking the car... not sure if this is related.
Ive gone through a few 'above average' puddles in the week at least twice.
Probably worth mentioning also that for the past two days the battery has been totally flat twice when going to start the car to get to work. I didn't know why this was happening and jump started the car with leads. I have since discovered that the reason for the battery discharge is because the radiator fan is stuck on spinning away. In order to stop my car battery draining I temporarily removed the appropriate fuse and drove the car for about half an hour whilst keeping an eye on the water temp dial just incase... not sure if this is related or not.
I'm going to locate, remove and dry out (if needed) the D4 connector tomorrow and cross my fingers. Other than that I think its done for... but there's hope as I know how clever you all can be.
Thanks for any help and advice.
Paz
Fault codes are:
U1702 - CAN network
Paz
