Posts: 24 Thanks: 3 Trader Rating: 0 Drives: | Problem list! Hi Guys, After getting 3 of the 4 engine mounts replaced a month or so ago the car was great...I say WAS because now I have the following issues I could do with some help on... 1. Passenger door has stopped locking via the button and fob...the window works via both. To top it off my electric mirror does not move when engaged in reverse... 2. Reverse sensors are not working...probably links the mirror problem. 3. A grinding feeling on quarter lock coming through the steering wheel...both ways. 4. low speed vibrations coming through the pedals...up to 40mph - not sure if this could be CV related but I do not get a clicking noise on full lock. It does make the whole car shake after a while... I have been twaling the forums and I have not come across much to help me.. Any ideas? \dicuss
__________________ 52 plate Fiat Stilo 1.9JTD Dynamic 112k on the clock & rising! 5 Door - for the family! Last edited by NotAgain; 29-06-2009 at 16:51. | ||
Posts: 32 Thanks: 7 Trader Rating: 0 | Re: Problem list! Which engine mounts did you change ?
__________________ '02 FIAT Stilo 1.9 JTD custom remapped + JR Sport Panel Filter, de-EGR, Throttle Body remove, FK-Automotive suspension | ||
| | #3 | ||
Posts: 6,427 Blog Entries: 1 Thanks: 244 Trader Rating: 0 Drives: | Re: Problem list! I would kinda expect it to be related to changing the engine mounts. Did any cable runs or plugs/sockets get crushed in the engine bay perhaps
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #4 | ||
Posts: 1,017 Thanks: 71 Trader Rating: 0 | Re: Problem list! 1. Check door hinge connector. They are prone to getting water in. Grinding / vibration, check CV joints and drive shafts.
__________________ WANTED: Stilo Front Ash Tray and Faulty Connect Nav+ for parts, to fix mine. | ||
| The following user says "Thank You!" to john55 for this useful post: | ||
NotAgain (14-07-2009) | ||
| | #5 | ||
Posts: 161 Thanks: 14 Trader Rating: 0 | Re: Problem list! Hi All The reverse sensor and mirror problem could be the reversing switch cable has been knocked off during the mounting change, are the reversing lights working? Is the grinding on the steering on the move or stationary? The vibration I would guess is almost certainly linked to the engine mountings that were replaced, which one wasn’t replaced?
| | #6 | ||
Posts: 24 Thanks: 3 Trader Rating: 0 Drives: | Re: Problem list! Thanks for the replies... Mounts: The only one i didnt change was the drivers side mount under the car. I thought it would take time to bed in (the other 3) but I have now done 1k+ miles since changing. We were as careful as possible to move the cable etc when fitting the mounts...but there is always a chance. I will check the doors for the connectors and the reversing lights and let you know. Don't like the sound of them not being waterproof! The grinding can be felt while stationary and in motion. Thanks,
__________________ 52 plate Fiat Stilo 1.9JTD Dynamic 112k on the clock & rising! 5 Door - for the family! | ||
| | #7 | ||
Posts: 1,017 Thanks: 71 Trader Rating: 0 | Re: Problem list! Just seen you have a JTD. It will be the reverse light switch in the gearbox that has failed for the reversing sensors. I bet if you look, the reverse lights themselves will not be coming on. Just search for reverse light switch. Lots of info on how to change it.
| | #8 | ||
Posts: 24 Thanks: 3 Trader Rating: 0 Drives: | Re: Problem list! The reverse lights do not work... I will comb the forum for this problem 1st, then tackle the rest. Update to come. Cheers guys.
| | #9 | ||
Posts: 161 Thanks: 14 Trader Rating: 0 | Re: Problem list! Hi Reversing light switch is an easy job it’s just behind the back of the n/s front wheel on the end of the gearbox you will need a 19mm offset ring spanner if it needs changing, check the wire is on first I think it’s the only wire down there so it should help you find the switch. Did the steering and vibration problems start immediately after the mounting change or did they come later?
| | #10 | ||
Posts: 24 Thanks: 3 Trader Rating: 0 Drives: | Re: Problem list! OK, well thanks for the information guys & decks guide ...I have replaced the reverse light switch tonight an hey presto, lights/sensors/wipers live! so a big thanks for that!!! Thats one crossed off the list ![]() As for the vibration i think I may have an idea. The inner CV's on both side are shot to bits...loads of play...so this is next. I am told this may cure the vibrations and the clunky steering noise on quarter turn. Tyres are not wearing unevnly so the tracking seems ok, plus only had it done 3k miles ago. Anyone know the part numbers for the inner CV's? ![]() Cheers.
| | #11 | ||
Posts: 32 Thanks: 7 Trader Rating: 0 | Re: Problem list! What do you mean by inner CV's ? EDIT: sorry for the question, I get it now Here're the numbers for the parts you need: http://62.195.105.49:7080/navi?MOD_C...OD=5&DRW_NUM=2 Glad you have fixed some of your problems, please report after changing ... I have the same problem as you might know. This week I'm also changing the mounts of the exhaust to see if there's any change in vibrations.
__________________ '02 FIAT Stilo 1.9 JTD custom remapped + JR Sport Panel Filter, de-EGR, Throttle Body remove, FK-Automotive suspension Last edited by radoslavp; 15-07-2009 at 07:31. | ||
| | #12 | ||
Posts: 24 Thanks: 3 Trader Rating: 0 Drives: | Re: Problem list! Thanks Radoslavp. I will keep you updated, it may take a week or so though. Hope your changes mean less trouble!
| | #13 | ||
Posts: 24 Thanks: 3 Trader Rating: 0 Drives: | Re: Problem list! Ok... Just got off the phone to my fiat dealer for the inner CV joint & boot... ![]() (46307103) CV new = £132.78 + VAT each (71781901) CV Recon = £56 + VAT + £30 Surcharge each (46307029) Boot = £36.25 + VAT each Thats around £380 inc VAT... My local spares place sells the outer @ £59.02 each but not the inner, says the inner could be dealer only. ![]() Why Fiat...WHY!!!
| | #14 | ||
| | Re: Problem list! Try motor factors, or even eBay. Those prices can be beaten | ||
| | #15 | |||
The wait is on...
__________________ 52 plate Fiat Stilo 1.9JTD Dynamic 112k on the clock & rising! 5 Door - for the family! | |||
| | GLTease | Cinquecento / Seicento | 2 | 20-04-2008 22:41 |
| | Bootlegdj | Stilo | 19 | 25-04-2006 09:18 |
| | joecinq | Cinquecento / Seicento | 36 | 14-09-2005 21:22 |
| my wish list..what ya think? | Little_red_buzz_box | I.C.E | 40 | 22-08-2005 23:13 |
| new to the list | thewalrus | Lets Talk FIAT | 3 | 17-08-2005 14:49 |
