somebeans
- Jan 19, 2009
- 31
- 6
i'm new to stilo's and i get the car security failure warning pretty much every time i get in the car. the car then doesn't turn off the immobiliser, so it won't go anywhere! if i turn the ignition off and back on again it usually clears it.
i have done a search through the forums and this seems to be a common-ish fault, just wondered if i am going along the right tracks with the thoughts i've got:
the other problem i've had is when i unlock the car sometimes the driver's door led carries on flashing until i press the unlock button again!
any thoughts?
cheers
- check out the d4 connector
- check battery
any thoughts?
cheers
