Bit of advice on having what seems like 1mm side to side play on off side front wheel, thinking it would be as simple as a track rod end
I have replaced track rod end but still have small amount of horizontal play when I jack car up and pull and tug the front wheel, vertical play is fine and have no noticable knocks or strange steering when driven,,can I rule out wheel bearings being worn, will be weekend when I can get someone to hold steering wheel firm and check the knock when I tug and pull wheel is still there and it is not just movement up through steering system, nearside is fine
If the play is still there when I get someone to hold steering wheel firm what should I be looking for at fault having already put a new track rod end on and with a mot due next month would it squeek through with an advisory ??
is a 1.9jtd mw with 88k miles on it.
