| Problem with Stilo - cutting out Forgive the lack of techincal terminology in this post but my stilo broke down in traffic today and I'm not sure where to start! It's a 4 year old 1.6 Dynamic - had it since March. I took it out of the drive this morning and I "stalled" 3 or 4 times few times before I realised that it wasn't my bad driving, but the car was cutting out after 3 seconds or so. IO was able to get it off the main road by restarting a few more times and getting a few seonds out of it every time. A quick poll of people suggests it's the fuel filter, but what now?! Tow to a garage? Try and drive it (3 seconds at a time ) to one? It is low on fuel (the low fuel sensor came on for the first time as I arrived home last night, but I thought I had plenty in it to get me to a petrol station - I live close to work and can often get 2 days work-home travel after my low fuel sensor beeps!)Thanks in advance for any advice.
| Whaddya mean too old? | Re: Problem with Stilo - cutting out Could do with more information When it starts does it start fine, hold a good tickover and then cut out as if you've turned off the ignition? Does it struggle to start, not hold a good tickover and then die? Fuel starvation can give symptoms of a fine start and tickover and then just die Have you tried releasing the vacuum in the tank by releasing the petrol cap? Are you on or do you park on a steep hill or perhaps on the pavement? What's your "range to empty" state? The more information you give the better the suggestions
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 24-09-2008 at 15:41. | ||
| | #3 | ||
| Re: Problem with Stilo - cutting out Currently have the same problem, cutting out, stalling ,losing revs. Took the car to a friends garage and he has used a diagnostics to tell me that it is an electrical problem that controls the throttle body. Thats all the info he has given me atm but the new part is £63+vat. Will update you shortly
__________________ Stilo 1.6 16v Dynamic '52' reg 3Dr Blue ![]() | |||
| | #4 | ||
| Re: Problem with Stilo - cutting out Try cleaning the butterfly on the air inlet control valve( idle valve) Then give it a good thrashing there is a guide on the forum somwhere. Try this http://www.fiatforum.com/stilo-guide...rol-valve.html Hope it helps
__________________ Stilo, 3door, 1.8 in Black. Fitted extra's 17"claws, Abarth skirts and Spoiler, Auto headlights, Headlight Washer Jets, Auto wipers, Rear Parking Sensors, Hifi upgrade , CD Multi-changer, Heated seats , Cruise Control, Bluetooth phone kit,Stainless Exhaust!![]() Now Eibach Suspension!![]() ![]() ![]() Xenon Headlights![]() ![]() | |||
| van cutting out and starting problem | shrekcardiff | Scudo | 0 | 25-02-2008 18:17 |
| punto cutting out problem | twinsparkspider | Newbie Central | 4 | 07-01-2008 18:50 |
| | cjk115 | Punto | 2 | 17-07-2007 19:08 |
| 1100 engine cutting out problem | Grommet | Tipo | 6 | 09-01-2007 09:39 |
| | sassy | Bravo / Brava | 1 | 25-07-2006 09:40 |
