The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Stilo
Old 04-09-2008   #1
Trader Rating: (0)
Brake lights!!!
Hi Guys, new poster here and hoping for some help!
Last week al of my break lights packed up!
Reading through the forum, changing the break switch seemed a good idea, done that and still no lights!
Ive checked all the bulbs and they seem in tact and ok.
Any help in diagnosing this problem would be greatly appreciated!!!!!!
trigger2641 is offline
Old 04-09-2008   #2
Freezing my arse off!
naaathaaan's Avatar
Trader Rating: (0)
naaathaaan has donated! United Kingdom
re: Brake lights!!!
simple one but, checked fuses?
Fiat Punto MK1 55
, Need Money, Need Mods.
Most of my posts are utter rubbish, But now and again i come out with something usefull and constructive, For these moments....there is the thanks button
naaathaaan is offline
Old 04-09-2008   #3
ABZSTILO's Avatar
Trader Rating: (0)
ABZSTILO has donated! United Kingdom
re: Brake lights!!!
But never heard of break lights before, maybe they're not intended to work (as they'd be broken).
'03 JTD Dynamic Grigio Steel with skyroof, Eibach -30mm prokit, Abarth shadow chrome 16" alloys with Vredestein Sportrac 3 tyres, OMP strutbrace.
ABZSTILO is offline
Old 04-09-2008   #4
Trader Rating: (0)
re: Brake lights!!!
Cant believe I wrote that!!! - See how stressed I am! Of course I meant "Brake lights". Just checked the fuses - All in tact.
This is really beginning to do my heeeed in.
Is it worth changing the bulbs anyway?
Im not sure cos its knocked the top light out as well
Old 06-09-2008   #5
ABZSTILO's Avatar
Trader Rating: (0)
Re: Brake lights!!!
I think the easiest solution is off to a garage with it
ABZSTILO is offline
Old 06-09-2008   #6
Whaddya mean too old?
Deckchair5's Avatar
Trader Rating: (0)
Deckchair5 has donated! United Kingdom
Re: Brake lights!!!
The fact that the hi level and lo level brake lights are both out would point towards supply or earth. I'd disconnect the connector at the brake light switch and check for power to the switch.
Got power? Ok you can dismiss fuses and supply.
Then i'd short out the two switch connector terminals so you bypass the switch. If it all works you know where your problem is. If they still don't work then you know the problem is downstream from the switch.
Name:	brake lights 1.JPG
The hilevel cluster F40 power comes directly from the brake light switch I30 but it does go through the body computer pin 15 to pin 5 so if the hi level isn't working could be on the power supply side of things
Name:	C30 left rear earth.JPG
But the whole lot is earthed at point C30 so a problem there would also knock everything out. Coo that's a bad design. Pointless having separate safety systems and then earthing them both at the same point
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline
(T) Speedo, Brake Lights & Reverse Lights Not Working cchheessyy Cinquecento / Seicento 4 21-03-2008 00:43
(G) Brake lights on Deckchair5 Stilo 5 22-10-2005 13:47
(T) brake lights. westie Stilo 3 14-06-2005 13:00
(T) Cinq Sporting Electrical Problem - Brake lights/rear lights namb Cinquecento / Seicento 3 20-02-2005 18:00
(T) Brake Lights Bob D Builder Punto 3 22-01-2004 05:58
