| NobodyBlamesTheHappyGuy:D | Anyone with a spare OCS sensor connector? Well, I'm so tired of the OCS sensor problems now, that I've bought a seat simulator from Germany. This will override the airbag system OCS sensor, and respond as permanently occupied. It can still be shut off with the key though. The mat costs over 3000 NOK (about 300 GBP with todays currencies). Norwegian prices are quite high as many of you are aware of. It is the baby seat that has destroyed it, and buying a new mat is no point, until I'm done making babies. ![]() But the simulator comes without the grey connector (from the cushion), so I'm asking if anyone has this one. The dealers here looks like big questionmarks when I tell them my plan. OCS? What is that? In a Stilo? No it doesn't have it! What? Stilo? Is it a Fiat? Grey connector? So you see that's why I ask overseas. If not, could anyone buy the damn connector and send it to me? Regards, Morten.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. Last edited by Morty Mort; 04-09-2008 at 16:08. | ||
| Whaddya mean too old? | Re: Anyone with a spare OCS sensor connector? Why not cut off the existing one and use that? I doubt if the connector is available to buy separately but a few owners may have old ones lying around they could send you. I wish I hadn't thrown mine away. This is the signal from a working OCS so no chance of a simple resistor or diode type simulator but if you can replicate this signal then you could make your own simulator for maybe a few pence of components Unless I'm mistaken, with the airbag failure warning on then none of the airbags will go off and anything has to be better than that
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 04-09-2008 at 15:14. | ||
| | #3 | ||||||
| NobodyBlamesTheHappyGuy:D | Re: Anyone with a spare OCS sensor connector?
![]() Here's the company: Air-Com Airbagsteuersysteme. www.airbag24.de. They send worldwide, handle English/American excellent, and have a very helpful staff. I did the order through e-mail, and I had several payment options (like PayPal).
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. | ||||||
| | #4 | ||
| Whaddya mean too old? | Re: Anyone with a spare OCS sensor connector? There's only 3 wires to the connector- 12v positive / negative and the signal wire so it'll be easy to wire in the simulator. It simulates an adult in the passenger seat all the time,as you know, but that's better than no air bags working on the car at all and you can still turn the pass airbag off as normal There is a solution for those in construction and building too. There is? The OCS is two sheets of thin plastic bonded together with a few load cells stuck in between the sheets. The more the load cells are depressed the greater the resistance and with a bit of quick calculation the ecu in the OCS can work out the weight and just where the weight is by the size and load distribution of your backside. Then it tells the airbag ecu what a Lardass you are! ![]() Anyway, what seems to happen is that these springy loadcells gradually break the bond between the sheets and then there's no resistance at the load cells and it all ends in tears So, if you simply bond a flexible but stiffer plastic sheet on the OCS then the ecu stops crying and everything works again but you have to make sure everything is dead flat whilst it's bonding so you need something like your entire porn collection on the top for the night Remember it'll take 3 clear starts for the warning to clear
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX | ||
| | #5 | |||||
| Grumpy Forum Moderator | Re: Anyone with a spare OCS sensor connector?
| | #7 | |||||||||
Anyway, I rarely sit in that seat...
Just to mention. Babyseats are OCS mat killers.
__________________ jet blue. 17" blades. eibach pro system. omp bar. gsr breath. mattig face. debadged. phoenix gold watts. rear tint. member of the 5-door massive attack. Last edited by Morty Mort; 04-09-2008 at 21:30. | |||||||||
| | #8 | ||
| Re: Anyone with a spare OCS sensor connector? Just a thought for any electronic wizards about but if it a case of a resistance measurement then if folk had a problem would there be a way of finding the size of resistor needed for specific weight ranges and figuring how to connect them in with removable connectors maybe something like 5 to 10 stone,,10 to 15 stone and so on , would make a cheap fix if it was possible and just a quick trip down to the local maplins for the resistor needed..may not be as simple as that but just had me thinking when deckchair mentioned resistance.
| | #9 | ||
| Whaddya mean too old? | Re: Anyone with a spare OCS sensor connector? The load cells are the resistance but then it checks out the capacitance so it can differentiate between a dead weight like a bag of shopping or a human. All clever stuff Yes baby seats or anything heavy or sharp on the ocs is not good
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 04-09-2008 at 22:02. | ||
| | #10 | |||
You can not replace the mat with resistors as each mat is calibrated to the controller after it is manufactured as the sensors are not accurately manufactured. There is also a second set of wires in the mat which act as a feedback, to check that the mat has continuity throughout and no broken wires exist. If either a break in the main mat, or the feedback circuit occurs then the controller assumes a fault. The feedback loops are capacitively connected to the main mat so not to affect the reading of the sensors. Maybe this is where you are getting confused about capacitive sensing. The mats can fail in many places (mine had broken connections in the area where it bends round the front edge of the seat). I tried to delaminate it and repair it, but it was hopeless as although only one track was probably broken, when I tried to delaminate it, other tracks were pulled away / broken in the process as they had become very fragile. The only way to replace it is either with another sensor, or an emulator. I hope to have an emulator working soon as I now have a working mat to test with in my car. Deckchair, do you have any more traces from the OCS, with different weights etc? Also, that trace is half from the Airbag ECU, with the OCS only sending a response to the Airbag ECU's request. It does not but data on the bus by itself, only when it receives the correct request. What is the frequency of the data packets? I can see from the trace that they are 14400 baud, but do you know any more about the format?
__________________ WANTED: Faulty Connect Nav+ for parts, to fix mine. | ||||
| | #11 | ||
| Whaddya mean too old? | Re: Anyone with a spare OCS sensor connector? As far as I know it uses fuzzy logic to work out the mass and distribution of the load in the seat. Each design of OCS is different and they keep their patents a well guarded secret. This is the only other OCS trace i took which doesn't show a whole lot apart from the sampling done approx every sec with the airbag ecu interrogating the OCS for changes If it's any help here's some other info on how the OCS works although this isn't a Stilo system. This shows how it detects not just the mass but how it's distributed. Deflection bending of the flat strip sensors give an indication of load distribution The next step is an infra red or grey scale camera to detect passenger size and position
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 12-09-2008 at 18:47. | ||
| | #12 | ||
| It's about GO! not SHOW! | Re: Anyone with a spare OCS sensor connector?
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: Pirelli P7; Pads: EBC GreenStuff; Oil: Castrol Edge 0W-30 fully synthetic | ||
| | #13 | ||
| Whaddya mean too old? | Re: Anyone with a spare OCS sensor connector? Yes that's right, the majority of fatalities by airbags in the early days were because the person didn't have their seat belt on. The seat belt is the first item of safety equipment and the airbag relies on the person being restrained by the seat belt first. Without it, the person would be flying into an inflating airbag and that's not nice at all as it would be like a sledgehammer. The airbag has to be expanded and already deflating when the person hits it. So if the seat belt isn't fastened then no airbag
__________________ 02 Stilo 1.6 Dynamic 3 door 99 Bravo 1.2SX Last edited by Deckchair5; 12-09-2008 at 19:38. | ||
| | #14 | ||
| NobodyBlamesTheHappyGuy:D | Re: Anyone with a spare OCS sensor connector? Hello again. Just to summarize (or whatever it's called) this thread. The simulator was mounted this weekend. And how wonderful everything is now. The beeps stopped after the initial start. The red airbag failure lamp lit up immediately, but vanished after 5 seconds. And it hasn't appeared since. The simulator is about the size of a matchbox, and is now ziplocked to the seat's frame. No fiddling at all. Just levered out the connection block holder under the seat, unclipped the grey one, cut the wires from it (no need for battery disconnection either), brought it inside and soldered the wires from the simulator to the wires from the cut-off wires from the grey block. They even had the same colors so you have to be a pure idiot to mess them up. Back to the car to connect the grey male/female blocks to each other again, mounted the simulator (it has long wires) and levered the connection block holder back under the seat. So now, everytime I start the car, the orange warning light flashes for a second, to tell someone is sitting next to me. Just as it used to do when someone sat down there - or I put a grocery bag etc. there. Everything works well. M.
| | #15 | ||
| Re: Anyone with a spare OCS sensor connector? why do you put your child in the front and not in the back seat and avoid this problem of destroying the matt sensor? plus in the back they have iso connectors i think their called to easily connect to baby seats its sort of a plug and play thing between the upper and lower part of the seats where the seatbelts come out of.
__________________ 1.6 silver dynamic 3d with skywindow, Schumacher Look, Abarth Pedals,Brembo Brakes,Bilstein Eibach Suspension, Eagle F1 Tires, K&N Filter,Sport Steering Wheel,Sport Knob,3M tint.Philips New Vision Lights. Founder & Admin of the Greek Stilo club www.stiloclub.gr | |||
| | XYFAS | Stilo | 7 | 4 Weeks Ago 12:11 |
| | stec | Stilo | 10 | 29-08-2008 09:51 |
| | IonutV | Stilo | 8 | 16-06-2008 20:20 |
| | larzmaster | Stilo | 13 | 26-09-2007 16:41 |
| | Deckchair5 | Stilo | 1 | 09-05-2006 14:20 |
